Max speed of new WiNG APs 7622 and 7602
‎01-18-2017 01:22 AM
Hi Community,
Two new APs 7622 and 7602 are have new operation modes as
concurrent single stream (1x1:2.4G + 1x1:5G), dual stream (2x2:2.4G or 2x2:5G), but i don't see the max speed each AP can reach in their datasheet.
So how is the actual max speed of them in two operation modes?
9 REPLIES 9
‎01-18-2017 02:15 AM
Hi, is there going to be an external antennas 7622 version or is it just internal?
Thank you all so much.
good catch - I will fix the datasheet ... here is quick breakdown
MAX DATA RATES
RADIO BW MODE 2x2 MODE 1+1 MODE
2G radio 20 11N 144.4 72.2
5G radio 20 11AC 173.3 86.7
2G radio 40 11N 300 150
5G radio 40 11AC 400 200
2G radio 80 11N N/A N/A
5G radio 80 11AC 866.7 433.3
MAX DATA RATES
Yes, both AP's have the same radio specs.
Thank you Blake Williams.
This can be seen clearly in AP 7602 datasheet with MSC but with AP 7622, this isn't shown.
Do two this APs have same spec?
