Need direction in setting up mesh for AP7662 APs
Brett_Morrison
New Contributor II
Hi
I have 4 of the AP7662 units setup with an auto VC, but I cannot work out how to mesh these correctly. The case will be that 3 of the 4 will be root devices (LAN access) and the 4th will not have LAN access, but will need to mirror the wireless in an open dispatch yard.
I have tried following 9035201_WiNG_5_9_1_AP_SRG.pdf but I cannot find some of the options in my APs. Is there a step by step guide for setting this up?
Thanks,
Brett
5 REPLIES 5
Ondrej_Lepa
Hello Brett,
you shall probably take a look to different guide.
Find MeshConnex Overview available from Documantation - Wireless & Mobility - Other Wireless Doc
You might have a SwiftUI loaded on your AP which looks pretty much different from the controller's graphical user interface. Try to use CLI instead or switch to EnterpriseUI
Let me know if you have further questions.
Regards,
Ondrej
