Problem with AP4600
‎10-07-2015 04:50 PM
Hello, my problem is that some Aps 4600 WM3600 are disconnected from the controller, and to re-sign, you must restart from the power source. Just think of two buildings belonging to the campus. And change the injectors but the problem remains.
I hope you can help me.
Greetings and thanks.
6 REPLIES 6
‎10-15-2015 04:54 PM
Great to hear you're all set.
Welcome to the Hub Community....really glad you joined.
‎10-15-2015 04:32 PM
Already I have been solved.
Apparently, it was only necessary to activate the auto-negotiation on the switch ports which are connected APs had flaws. Leave them in observation, and have more than a week without problems and previously failed daily.
The Tech-support I could not get the controller, because attempts to do the WM restarted. Extreme I shared a patch to fix this, but I could not install it yet.
Thank you.
Thank you.
For anyone coming across this thread in the future, the patch that Jorge mentioned is described in the GTAC Knowledge article below:
WM3600 controller reboots while taking tech-support
‎10-15-2015 04:21 PM
Jorge....did you resolve? The team wants to make sure you're good to go.
