Problems with AP650 being adopted by RFS6000
GUTAN_Flaviu
Hello,
For 2 years, we have APs failing to reconnect to our RFS after programmed electricity cut. They are shown as offline in Wing and phisically the Amber led is blinking every 2 sec. or so and the green led is off. I tried connecting them directly to the RFS but nothing changed. We bought 3 more APs on e-bay and we have the same issue. Tried to reset the AP using the Motorola_AP_Discovery_Tool but I see the AP connecting to the RFS and then disconnecting itself 3 or 4 seconds later. For now we have at least 5 unusable APs all with the same symptoms. Any help or advice would be appreciated as we still have to continue with this infrastructure for atl least 8 months. Thank you
35 REPLIES 35
GUTAN_Flaviu
what in your opinion would the problem be? It's strange that we have 5 APs (2 previously adopted ) and 3 newly purchased (from ebay, I agree that the guarantee is not assured) that won't work.
GUTAN_Flaviu
 I would have done it if our support was still active ... unfortunately it isn't 😞
aholden
That is correct.
You mat want to consider opening a SUPPORT Case.
aholden
The AP650 is a "DEPENDENT" AP. It needs the controller to push out the configuration. If the AP is on the same broadcast domain, there will be no issue. If the AP is on a different subnet then the controller, the "CONTROLLER HOST" variable is needed. On a power fail/ reboot, all configuration data is lost on the AP650 and if they are on a different subnet, they will not be able to locate the Controller. If this is the case, the CONTROLLER HOST variable can be set using DHCP Option 191
Andy,
connecting the failing APs directly to the RFS ports should allow the AP to locate the controller without any problems, right?
