Roaming Assist Guide
Richard_Augusto
Contributor
Good Morning!
I'm implementing measures to improve WiFi in high density and critical environments. I have a scenario with 17,000 people passing by continuously.
Motorola left a very interesting role called Roaming Assist, but I did not find any deploy guides.
We have 6 functions to customize. I need help refining this functionality.
I would like tips used to keep clients connected to critical mission SSIDs and SSIDs for non-critical systems (avoid sticky clients)
Do you have any guides? The most I found was a motorola white paper explaining how the technology works.
Thanks!
5 REPLIES 5
Andrew_Blomley
Roaming Assist works by monitoring the received rssi of the mobile device
The access point monitors any device that the received rssi goes below detection-threshold.
When the device hits the handoff-threshold, the action is performed, in this case, assisted-roam
Below is an example policy
roaming-assist-policy
aggressiveness lowest
sampling-interval 15
monitoring-interval 5
handoff-count 3
detection-threshold -65
handoff-threshold -70
action assisted-roam
disassoc-time 5.
To assign this policy to a wlan.
select the wlan
Config
Wlan
Use roaming-assist-policy
