WiNG 7.6 AP310 dropping tcp keep-alive after roaming
Jacek_Skorzewsk
Hi, I have an issue with locally bridged trafiic on AP310 running WiNG 7.6.
The wifi client has a MSSQL database (tcp) session open.
The session goes idle, the server starts keeping the seession up by sending tcp keep-alive packets.
When roaming occurs, no tcp keep-alive ACK’s are seen from the wireless station.
Could it be firewall-policy behaviour? Stateful L2 packet inspection is enabled.
Cheers
Jacek
1 ACCEPTED SOLUTION
Douglas_Novell
Hello,
It is possible that the firewall is impacting the session. Please see this article for the suggested WiNG firewall configuration: https://extremeportal.force.com/ExtrArticleDetail?an=000087636
If this does not resolve theissue it is suggested to open up a Support case with GTAC for further analysis with a TechSupport from the Controller.
1 REPLY 1
Douglas_Novell
Hello,
