Wing EAP-TLS help
Wing EAP-TLS help
Bart_Bielewicz
New Contributor II
I've been fallowing the below guide for EAP-TLS. Would anyone got more documentation please? This is the first time im trasked with EAP-TLS and could fo with more info.
How To: How to configure WiNG based RADIUS server to process EAP-TLS authentication? | Extreme Porta...
Force remove preview
How To: How to configure WiNG based RADIUS server to process EAP-TLS authentication? | Extreme Portal
First of all, make sure you have following done: proper PKI setup to issue certificates for clients & trustpoints your wireless client has proper personal | machine certificate installed with corresponding private key your APs have a valid trustpoint from the same SSL chain of trust If you do not know How to import digital certificate to WiNG controller, follow the relevant article.
View this on Force >
Regards
Bart
5 REPLIES 5
LudwigD
Thanks for sharing this info this is useful keep it up.
mcdvoice customer survey
