Wireless Wing Ap7632i configure roaming cli
Vladimir2k3
Good afternoon.
I have two Ap7632i points, I need to configure them in the bridge, receive ip addresses via dhcp, Configure one point as a virtual controller, create a roaming with one ssid between the points. (The task is this: you need users who use W-fi to automatically switch to another point.)
Please tell me how it is fashionable to do it through the Kli?
version fremware 5.9.6.0-007R
5 REPLIES 5
Tomasz
Valued Contributor II
Hi Vladimir,
Sorry for a delayed response. By what means one AP goes offline? Does it stop advertising SSID (just one BSSID seen with apps like InSSIDer, Netspot, Wi-Fi Analyzer etc.), stops working at all, or when you are connected to one AP you don’t see the neighbor (ā€˜show mint neighbors’, ā€˜show mint links’)?
Would that be possible to share the config here?
It definitely shouldn’t happen that way that only one AP is operational at a time.
Hope that helps,
Tomasz
Vladimir2k3
Yes, that's right, that's what I mean.  I can't configure both points so that both are in the same wi-fi network, I get either one wi-fi point or, one online, the other offline (
Tomasz
Hi Vladimir,
I’m sorry but to make sure, you mean Wi-Fi roaming so that wireless clients roam between them while moving? That’s a natural feature of Wi-Fi networks but may require config improvements in certain scenarios.
Kind regards,
Tomasz
Vladimir2k3
Thanks for the links, but is there anything about configure up roaming between two wi-fi points via cli?
