Wireless WM3600 and AP4620 roaming problem : Client IP 0.0.0.0 when roaming from an AP to another
Grossi_Nicola
Hallo,
this is my firt post on this community.
I have a problem with a WM3600 system (2 in cluster) and access-point AP4620 when a device roaming from an AP to another. The client in dhcp mode acquire the correct IP when associated to the first AP and all ok; when the device roam to another AP, the client info report an IP 0.0.0.0
This is the syslog report of the roaming problem :
AP1 - AP1 %DOT11-6-CLIENT_ASSOCIATED: Client '90-68-C3-49-F0-BC' associated to wlan 'POLI_SMART' ssid 'POLI_SMART' on radio 'AP1:R1'
AP1 - AP1 %DOT11-6-CLIENT_INFO: Client '90-68-C3-49-F0-BC' IP address '192.168.104.2', bssid '00-04-96-6C-52-D2' of radio 'AP1:R1' signal-strength -69dBm
AP1 - AP1 %DOT11-6-CLIENT_DISASSOCIATED: Client '90-68-C3-49-F0-BC' disassociated from wlan 'POLI_SMART' radio 'AP1:R1': roam detected (reason code:8)
AP2 - AP2 %DOT11-6-CLIENT_ASSOCIATED: Client '90-68-C3-49-F0-BC' associated to wlan 'POLI_SMART' ssid 'POLI_SMART' on radio 'AP2:R1'
AP2 - AP2 %DOT11-6-CLIENT_INFO: Client '90-68-C3-49-F0-BC' IP address '0.0.0.0', bssid '00-04-96-90-B2-B1' of radio 'AP2:R1' signal-strength -47dBm
Can you help me ?
Thank
5 REPLIES 5
Add some info
In this condition the Wireless Firewall Policy drop all traffic, but if i disable the policy the traffic is ok.
The SSID is tunneled
The wlan is a wpa2 pks
The DHCP in a win2012 server (dhcp replay)
There is a radius for the mac-address authentication
