Enterasys Wireless f/w 8.11.06.0006 Multi-Edit Feature Use can Disable AP Radios
FAQ_User
Article ID: 14930
Products
Enterasys (formerly HiPath) Wireless Controllers
C20, C25, C4110, C5110, V2110; firmware 8.11.06.0006
Enterasys (formerly HiPath) thin Access Points
RBT-4102, RBT-4102-EU, AP26xx, AP36xx
Changes
Used the Multi-Edit feature to make multiple Access Point (AP) radio setting changes.
Symptoms
The changes were accepted but the AP radios turned off.
Cause
When the controller is pushing down the new AP radio configuration changes, there is an inadvertent setting change not allowed, so the radios end up being disabled.
Solution/Workaround
Upgrade to firmware 8.11.07.0007 or higher.
Release notes state, in the 'Changes in 8.11.07.0007' section:
code:
wns0007969 wns0008368
code:
Resolves issue where AP radios are disabled after multiedit changes applied
Pre-upgrade workaround:
  1. Go to the AP Multi-Edit section in the GUI.
  2. Choose the APs to edit from the current configured list.
  3. For each radio; make sure that Admin Mode is set to 'enabled', the Radio Mode is set to a value (Radio 1: 'a', 'a/n', 'n-strict'; Radio 2: 'b', 'g', 'b/g', 'g/n', 'b/g/n', 'n-strict'), and the Antenna Selection is set to 'Left/Middle/Right'.
  4. Set all other desired configuration changes before applying the multi-edit.
0 REPLIES 0
