G-Series f/w 6.61.07.0010 Reboots if I/O Module Power Off button is pressed for 8+ Seconds
‎11-20-2014 02:54 PM
Article ID: 14982
Products
G-Series; firmware 6.61.06.0009, 6.61.07.0010
Changes
Pressed and held for 8+ seconds (the Hardware Installation Guide recommends 5 seconds) the '
Symptoms
Unit reboot.
The current.log (5487) displays a "
Upgrade to firmware 6.61.08.0013 or higher.
Pre-upgrade workaround: Avoid pressing the button for longer than 6 seconds.
Products
Changes
code:
' button corresponding to a targeted IOM slot, in preparation for removing the IOM from that slot.POWER OFF
Symptoms
Unit reboot.
code:
<Task EDB BXS Resp(
address>
code:
" message with last reset cause ") is suspended...
code:
"; for example:Fault(0x00000300)
160>
Sep 3 03:43:37 172.17.8.120-1 SIM[104439944]: hwutils.c(7536) 762 %%
ERROR:Code exception:Watchdog no longer being serviced.
Task EDB BXS Resp(0x7fab848) is suspended with error 2, creating file sysDmp1Sep0312.z<
57>
SEP 03 03:44:17 2012 BOOT[268430624]: bootos.c(1360) 760 %%
Start of Code - Build:06.61.06.0009 Date:Wed Jul 25 18:47:14 2012<
110>
SEP 03 03:44:20 2012 BOOT[153225176]: edb_bxs.c(1235) 764 %%
Last switch reset caused by Fault(0x00000300) SRR0(0x01218D08) SRR1(0x0000B030) DMISS(0x00000000) IMISS(0x00000000) DAR(0x00002264) DSISR(0x0A000000)The sysDmp (13650) file states "
code:
" and the diagnostic points to "Task Name: EDB BXS Resp
code:
"; for example:faultbias
Detailed exception task information
Calling Stack:
Task ID:
0x7fab848Task Name:
EDB BXS RespPC:
0x1218d08
PendQ:
0x7f5184c
SP:
0x7fa4df0
0x1218d08: bfill (0x1218cbc) + 0x4c
0x5ce30: faultbias (0x5b520) + 0x1910
0x5f0dac: edbBxsRspTask (0x5ef044) + 0x1d68
0x121b9c4: vxTaskEntry (0x121b968) + 0x5cSolution/Workaround
0 REPLIES 0
