How to Redeem and Activate an Enterasys Product License
FAQ_User
Article ID: 10833
Products
B2-Series
B3-Series
C3-Series
C5-Series
G-Series
K-Series
S-Series
7100-Series
IdentiFi Wireless
NetSight Suite
Goals
The above-stated products support the application of licensing to permanently unlock certain firmware features, or to install software. Customers who purchase one or more of these licenses will receive for each, either via email or on paper, an "Entitlement ID" (also known as a "Web Key") entitling them to a single-unit or multi-unit license.
This document discusses how to process a purchased Entitlement ID to obtain a license character string suitable for installing into an Enterasys switch/router, or into an application server.
Solution
* Log into the Enterasys Licensing portal *
  1. Browse to https://extranet.extremenetworks.com/MySupport/Licensing/.
  2. As necessary, use the "
    Create an account now
    " or "
    Forgot your password?
    " links.
  3. Type your
    User Name
    (registered e-email address) and
    Password
    into the text boxes, and click the
    Sign In
    button.
    * Locate your Purchased License *
    -or-
    * Request an Evaluation License *
    On the "
    Welcome to Enterasys Licensing
    " page, if you have purchased a license, skip to step 10.
  4. Click the '
    Evaluation License Request
    ' link.
  5. Select the proper Product Family dropdown list item: Select a Product Family: Choose one... SecureStack NetSight Enterasys Fixed Switching Identifi Wireless S-Series K-Series 7100-Series
  6. Select the proper Product dropdown list item: Select a Specific Product: Choose one... SecureStack B3 Policy Evaluation Feature SecureStack C3 Advance Router SecureStack C5 Advance Router NetSight Suite NMS Wireless Advanced Services G3 Advance Router Evaluation Feature G3 IPV6 Evaluation Feature V10 REG DOMAIN EVAL KEY FOR BASE V10 REG DOMAIN EVAL KEY FOR FCC V10 REG DOMAIN EVAL KEY FOR ROW V10 V2110 REGULATORY DOMAIN EVAL KEY FOR BASE V10 V2110 REGULATORY DOMAIN EVAL KEY FOR FCC V10 V2110 REGULATORY DOMAIN EVAL KEY FOR ROW V9 REG DOMAIN EVAL KEY FOR ISRAEL V9 REG DOMAIN EVAL KEY FOR JAPAN V9 REG DOMAIN EVAL KEY FOR NAM V9 REG DOMAIN EVAL KEY FOR ROW V9 V2110 REGULATORY DOMAIN EVAL KEY FOR ISRAEL V9 V2110 REGULATORY DOMAIN EVAL KEY FOR JAPAN V9 V2110 REGULATORY DOMAIN EVAL KEY FOR NAM V9 V2110 REGULATORY DOMAIN EVAL KEY FOR ROW S130 CLASS ROUTING LICENSE S150 CLASS ROUTING LICENSE SSA DOUBLE USER CAPACITY LICENSE S-SERIES EOS PPC VSB MULTI-SLOT CHASSIS BONDING LICENSE VSB S1 CHASSIS BONDING LICENSE VSB SSA CHASSIS BONDING LICENSE K-SERIES ADVANCED ROUTING LICENSE K-SERIES PER PORT USER CAPACITY LICENSE K-SERIES VIRTUAL SWITCH BONDING CHASSIS LICENSE 7100 ADVANCE ROUTING LICENSE 7100G ADVANCED ROUTING LICENSE
  7. Click the
    Submit
    button.
  8. You will receive an email which includes instructions and your Entitlement ID - exactly the information a license purchaser would receive, except that the resulting license will expire 30 days from the completion of step 8. Note that a given user may request only a limited number of evaluation licenses.
    * Redeem the Entitlement ID to add it to your Licensing Account *
    On the "
    " page, whether you have a purchased or evaluation Entitlement ID, click the '
    Redeem Entitlement ID
    ' link.
  9. On the "
    Redeem Entitlement ID Request
    " page, fill in the text box information for the new Entitlement: Entitlement ID: <Entitlement ID> Entitlement Description: <Description for your later license management use>
  10. Click the
    Redeem
    button.
      Note: If you receive error message "
      code:
      The Entitlement Id entered does not exist in the licensing system.
      ", there are at least two reason for this:
        - The entered ID does not contain the dash characters ("-") which are required to be present between the multiple alphanumeric character groups. If for example you are emailed Entitlement ID "
      code:
      ef137d1271ba1541c79b0
      ", the ID you need to enter is "
      code:
      ef13-7d12-71ba-1541-c79b-0
        - The characters "0", "O", "1" and/or "I" are part of the ID but have been misinterpreted and mistyped when entering the ID.
        If neither of these conditions seem to apply, then please
      contact the GTAC for assistance.
    • The "
      code:
      ...Entitlement ID has been verified...
      " reply includes the newly added item: Entitlement ID: Manage this Entitlement
      * Activate the Entitlement ID...
      License activation requires that a minimum of one parameter (and possibly more, product-specific) be entered, in order to complete the final phase of generating the license key string that must be entered into the end product in order for it to recognize the entitlement and activate the feature. The required parameter is one of the following:
      • end customer Company Name (for C5/K/S/7100-Series, and NetSight v4.2.1* and higher) - Skip to step 15.
      • destination Controller or Server MAC Address (for IdentiFi Wireless (14973), and NetSight v2.2 through v4.4*) - Skip to step 22.
      • destination Switch Serial Number (for B2/B3/C3/G-Series) - Skip to step 29.
      *NetSight v4.2.1 through 4.4 supports both license types (5368), to assist with the transition process.
      ...against an end customer Company Name *
      On the "
      code:
      " page, click the '
      code:
      My License List
      ' link.
    • On the "
      code:
      My Licenses List
      " page, from the list of your managed (but unActivated) licenses, select the Entitlement ID to be Activated.
        Note1: The mention on this web page of the user's ability to toggle licenses between Active and InActive status, and filter the license view based those attributes, is strictly a user management convenience. These are not related to the process of Activating a license as discussed in this KB document.
          Note2: If you cannot locate the Activation ID you just redeemed in step 12 with this account, see 12752.
        • On the "
          code:
          License Details
          " page, click the
          code:
          Activate
          button.
        • In the "
          code:
          Key Activation Details
          " section, enter the Company Name of the end customer. Inclusion of spaces is permissible, but please avoid "special" characters outside of a-z, A-Z, and 0-9 with punctuation. Use of such "special" characters may cause the generated Activation Key to not be accepted by the licensed product.
        • Click the
          code:
          Generate
          button.
            Note: In the case of a multi-license purchase (listed Quantity greater than 1), after redemption the license instances will each be listed for
            code:
            Activate
            or
            code:
            Re-gen
            action, to derive multiple unique Activation Key strings each tailored for a given install destination.
          • On the "
            code:
            License Details
            " page will be displayed the Activation Key to be used to copy and install onto the product. This key string is very long - about 150 characters - and ends with "==". Only about the first half of it is visible in the display window. If the copied text string does not end with the double equal signs, then the license key has not been fully captured, so must be re-copied. Product: <License Part#>
            MAC Address:
            Serial Number:
            Re-gen Company Name: My Demo Company
            Activation Key:
            Very:LongActivation:KeyBinding:My Demo Company:WithMuchEncryptedDataAndEndingWithDoubleEqualSignLike==Here are sample Activation Key mock-ups of various license part numbers: C5L3-LIC . . . 0001:C5L3-LIC:1:4feb0932:0:My Demo Company:0:8d867148ls< -75 characters snipped- >58lUCY0DD9A==
            71A-EOS-ADVL3 . 0001:71A-EOS-ADVL3:1:52ea0d97:0:My Demo Company:0:8d867< -75 characters snipped- >gbVuuj6tc4sDujQA==
            71A-EOS-G-ADVL3 0001:71A-EOS-G-ADVL3:1:52ca756d:0:My Demo Company:0:8d8< -75 characters snipped- >rTPWR/fLn+ZJ3lSIhA==
            K-EOS-L3. . . . 0001:K-EOS-L3:1:5011a29b:0:My Demo Company:0:8d86714dZs< -75 characters snipped- >6YrkO9ml1w==
            S-EOS-L3-S130 . 0001:S-EOS-L3-S130:1:50746549:0:My Demo Company:0:8d8Pt< -75 characters snipped- >JhQM8W4v8ldFzPQ==
            S-EOS-PPC . . . 0001:S-EOS-PPC:1:4d77c805:0:My Demo Company:0:8d86264wx< -75 characters snipped- >Yw0+OOspelQ==
            S-EOS-VSB . . . 0001:S-EOS-VSB:1:513af0a5:0:My Demo Company:0:8d86714YO< -75 characters snipped- >1SUMkYPSVKQ==
            S1-EOS-VSB. . . 0001:S1-EOS-VSB:1:500d5073:0:My Demo Company:0:8d8671wA< -75 characters snipped- >WSAXc7vnuLJA==
            SSA-EOS-VSB . . 0001:SSA-EOS-VSB:1:4fc9042a:0:My Demo Company:0:8d86714< -75 characters snipped- >ClSOFVdIyC20U==
            SSA-EOS-2XUSER. 0001:SSA-EOS-2XUSER:1:41183432:0:My Demo Company:0:8e86< -75 characters snipped- >71nd:yOsMP6kw2la==
            NS-AB-U . . . . 0001:NS-AB-U:1:5123adaa:0:My Demo Company:0:8d86714d:5y< -75 characters snipped- >Y7b1C86+A==
            NS-WADVSVC4 . . 0001:NS-WADVSVC4:1:5064da3d:0:My Demo Company:0:8d86714< -75 characters snipped- >tLz0EnBGj2iQg==
            NS-WS-CAPUP1. . 0001:NS-WAS-CAPUP1:1:5064daaa:0:My Demo Company:0:8d867< -75 characters snipped- >TgVhEVThyaIyCnw==At any time you may manage your licenses, and copy the Activation Key from displayed detail of any given license.
            If a license has been incorrectly Activated, then please contact the GTAC for assistance.
          • Click the
            code:
            Sign Out
            link, then skip to step 37.
            ...against a Controller or Server MAC Address *
            On the "
            code:
            " page, click the '
            code:
            My License List
            ' link.
          • On the "
            code:
            My Licenses List
              • On the "
                code:
                License Details
                " page, click the
                code:
                Activate
                button.
              • In the "
                code:
                " section, enter the controller or server MAC address applicable to where the license will be installed. This must be entered without spaces or punctuation (e.g.
                code:
                0000abcdef01
                ). For Wireless licensing, also enter the Install Country which must conform with the license model being activated.
              • Click the
                code:
                Generate
                button.
                  code:
                  Activate
                  or
                  code:
                  Rehost
                • On the "
                  code:
                  License Details
                  " page will be displayed the Activation Key to be used to copy and install onto the product. For NetSight licenses, note that this view contains a Rehost option, for limited rehosting in the event that the installed MAC address changes (e.g. due to Server reinstall). Product: <License Part#>
                  MAC Address: <xx-xx-xx-xx-xx-xx>
                  Serial Number:
                  Rehost Company Name:
                  Activation Key:
                  MODERATELY-LONG-ACTIVATION-KEYHere are sample Activation Key mock-ups of various license part numbers:WS-REG9P-NAM. . . PRDKNAM-LF1X48BS-LZCI71R3-SAF4UZ0R-Q9CDUJC3
                  WS-REG9P-ROW. . . PRDKROW-QPL7N80V-V5BSRHDR-ND9S4YPQ-NCDNO596
                  WS-V2110-9-NAM. . PRDKVNAM-NE4UQY96-3ICKJ89R-2B75PXI5-6F9GMFXR
                  WS-V2110-9-ROW. . PRDKVROW-OF5VSZ07-4JDMK90L-3C86NYJ6-7G0HNYYS
                  WS-APCAP-25 . . . CAPCTL-QF0OVAJ3-QAZRSBAV-R8GVA99N-4J13UP5T
                  WS-CTLCAPUP25 . . CAPCTL-SAAEK1ZX-45JHRFOQ-LJPSX2D4-7Z2XQ5PO
                  WS-C20XCAPUP16. . CAPC20-4Y8QO8LP-HACRIA8H-UCYUX0FO-UP0LSG14
                  NS-CON-50 v3.1. . INCREMENT Console ets 2009.0115 permanent uncounted VENDOR_STRING="
                  type=server devices=50 clients=3 model=all"
                  HOSTID=0051263f0017 ISSUED=5-mar-2013 START=16-dec-2008
                  SIGN="0985 2D4E 31BB BE20 5D20 7EB3 9C19 F404 DF50 39FE C748
                  D621 E613 5D74 9DC6 0F8B 43DB B6A2 ECD8 BD3B 8A97 4B9A 709C
                  0FCB 44D4 7F3E 49A6 4CDE 8609 DAF1"
                    If a Wireless license requires Rehosting, then please
                    If a NetSight license requires Rehosting, then please refer to the procedure at the bottom of this document. As necessary, feel free to
                • Click the
                  code:
                  Sign Out
                  ...against a Switch Serial Number *
                  On the "
                  code:
                  " page, click the '
                  code:
                  My License List
                  ' link.
                • On the "
                  code:
                  My Licenses List
                    • In the embedded "
                      code:
                      Enterasys Licensing
                      " page, click the
                      code:
                      Activate
                      button.
                    • In the embedded web page where it lists the "
                      code:
                      Activatable Line Items
                      ", click the check-box to select the one item shown, then click the
                      code:
                      Activate
                      button.
                    • In the embedded "
                      code:
                      activate licenses
                      " page, fill in the text box information to (optionally) identify your ownership and to generate a license tailored to your installation: Ship to Mail: <email address>
                      Node-Locked HostId: ID_STRING=<Switch_hardware_serial#>
                    • Click the
                      code:
                      Generate
                      button.
                        Note1: If you receive error message "
                        code:
                        Invalid Host ID:
                        serial#
                        code:
                        # nnnn-nnnnn
                        ", this is because the entered serial# contains digits other than 0-9, a-f, or A-F. These serial numbers must be entered starting with "
                        code:
                        ID_STRING=
                        " (otherwise optional, this formatting in all cases has the additional desirable side-effect of capitalizing any serial# letters in the resulting license string). For instance, "
                        code:
                        ID_STRING=07371504025G
                        " instead of "
                        code:
                        07371504025G
                        ". As explained in the Licensed Product Entitlement ID instructions received upon purchase of a feature license, this is the recommended method.
                          Note2: In the case of a multi-license purchase such as the B2POL-LIC25/50 or B3POL-LIC25/50, the same ID may be run through the Activation process multiple times up to the limit of the license, to derive multiple unique Activation Key strings each tailored for a given install destination.
                            Note3: If you receive error message "
                            code:
                            The activation of the fulfillment is denied by the activation policy because fulfill count exceeded the seat count # nnnn-nnnnn
                            ", this is because the license has already been tied to the maximum number of hosts (as is viewable in "
                            code:
                            view licenses
                            "). If one of its existing licensed hosts is no longer in licensed use, you may rehost this license from the existing licensed host to the new licensed host. Otherwise, please use a different license.
                          • On the embedded "
                            code:
                            view licenses
                            " page will be displayed the license key to be used to copy and install onto the product.
                            Here are sample mock-ups of various license types:B2POL-LIC . .INCREMENT B2Policy 2008.0711 permanent 7C3AA3B9C49C 08221259225H
                            B3POL-LIC . .INCREMENT policy 2008.0310 permanent 1D9FC9AF4CD8 08132937225F
                            C3L3-LIC. . .INCREMENT advrouter 2008.0822 permanent 01AFF04E975B 07040174905B
                            C3IPV6-LIC. .INCREMENT ipv6router 2008.0829 permanent EEAA3C8C8E54 063021329041
                            G3L3-LIC. . .INCREMENT G3advrouter 2008.0830 permanent B1519290349A 08031829904A
                            G3IPV6-LIC. .INCREMENT G3ipv6router 2008.0830 permanent C5FF69B12341 08041171223AAt any time you may manage your licenses, and copy the Activation Key from displayed detail of any given license.
                            If a license requires Rehosting, then please refer to the procedure at the bottom of this document. As necessary, feel free to contact the GTAC for assistance.
                          • Click the
                            code:
                            Sign Out
                            link.
                            * Install the License into the Product *
                            The license install procedure is dependent on the product and version, as outlined below:
                            • To install SecureStack B2 Policy licensing, see 5781.
                            • To install SecureStack B3 Policy licensing, see 5781.
                            • To install SecureStack C3 Advanced Router licensing, see 5828.
                            • To install SecureStack C3 IPv6 Router licensing, see 5873.
                            • To install C5-Series Advanced/IPv6 Router licensing, see 13130.
                            • For a broader view of SecureStack licensing, see 5834.
                            • To install G-Series Advanced Router licensing, see 10824.
                            • To install G-Series IPv6 Router licensing, see 10834.
                            • To install K-Series EOS licensing, see 15004.
                            • To install S-Series EOS licensing, see 15003.
                            • To install 7100-Series Advanced Router licensing, see 16096.
                            • See 5368 for NetSight license/version applicability.
                            • To install HiPath/Enterasys/IdentiFi Wireless product licensing, see 16133.
                            • The licensing of any other products (e.g. C2-Series (5828), D-Series (10791), and N-Series (5025, 5468)) is not part of the online licensing system as described in this document.
                          * Rehost the License after Switch Hardware Replacement or NetSight App reinstall *
                          If a B2, B3, C3, or G-Series unit with installed license (steps 29-36 above) has been replaced via RMA, or if a NetSight server with installed license (steps 22-28 above) has been replaced, then customers and partners may directly rehost (from the old device to the new device) a limited number of times per year.
                          Follow this procedure:
                          1. Browse to, and log into, https://extranet.extremenetworks.com/MySupport/Licensing/.
                          2. On the "
                            " page, click the '
                            My License List
                            ' link.
                          3. On the "
                            My License List
                            " page, click the
                            Entitlement ID
                            for the product that you wish to rehost.
                          4. In the embedded "
                            Enterasys Licensing
                            " page, clck the '
                            Manage Licenses
                            ' link.
                          5. From the list of your managed (and Activated) licenses, checkbox-click the item to be Rehosted.
                          6. Click the
                            Rehost
                            button.
                          7. On the embedded "
                            select entitlements to activate
                            " page, fill in the text box information to (optionally) identify your ownership and to rehost the selected license: Ship to Email: <email address> Node-Locked HostId: ID_STRING=<Switch_hardware_serial#> -or- <NetSight_server_MAC_address>
                          8. Click the
                            Rehost
                            button.
                          9. On the "
                            view licenses
                            " page will be displayed the new license key to be used to copy and install onto the product.
                          10. Click the
                            Sign Out
                            link.
                          If you need assistance with any of this, please contact the GTAC.
                        0 REPLIES 0
