NetSight - Telnet and SSH no Longer Work From Within NetSight After Java Upgrade
‎09-04-2013 11:01 PM
Article ID: 15036
Products
NetSight Console, version 4.4
NetSight Inventory Manager, version 4.4
Changes
Java was updated to version 1.6 update 45 or version 1.7 update 21.
Symptoms
When attempting to start a telnet or ssh session from within NetSight the following error will appear:
Cause
There were changes made to how Java handles Runtime.exe. More information is available in the release notes for the Java version that is being used.
Solution/Workaround
Upgrade to NetSight Suite version 5.0 or higher.
Release notes state, in the 'Console Issues Addressed' section:
Pre-upgrade workaround:
Downgrading to the following versions resolves the issue with telnet/ssh:
Java 1.6 update 43
Java 1.7 update 17
Products
Changes
Symptoms
code:
Executable name has embedded quote, split the arguments
Cause
Solution/Workaround
code:
Corrected a Java compatibility issue that prevented Telnet and SSH from being run from a NetSight client. 932410
Java 1.6 update 43
Java 1.7 update 17
0 REPLIES 0
