‎07-06-2015 04:53 PM
show config bonding
1
2
Bonded SSA Chassis(su)-
show config bonding
This command shows non-default configurations only.
Use 'show config all' to show both default and non-default configurations.
begin
# ***** NON-DEFAULT CONFIGURATION *****
# Chassis Firmware Revision: 07.71.01.0010
# bonding
set bonding
chassis 2
system-id 1
serial-number 11536214686C
set bonding
port tg.2.1
enable
set bonding enable
end
2
1
tg.1.1
show config license
show config license
begin
# license
set license vsb "0001:SSA-EOS-VSB:1:4c804c0c:0:Enterasys Networks GTAC:0:80862a4d:p8bhDiSOEtY3dxhw1O6BX7lZjK56gLV9twGBChA/UMDcBnF3uS4ah9DMnXFJMzw8cXaBpNoz6o9D/vnprn3XtQ==" chassis 1
set license vsb "0001:SSA-EOS-VSB:1:4c804bb7:0:Enterasys Networks GTAC:0:80862a4d:raxhEcEU3OFzDr7G1cSncFXgwg2Erl49rbe4B3nNJ6OUcf2j/DPhg2VVP2GwKOBc1570GcxPEY6TntI8E6XnCw==" chassis 2
end
show config outfile
show config outfile slot2/fullConfig.cfg
SSA Chassis(su)-
SSA Chassis(su)-
set bonding chassis 1 system-id 1
SSA Chassis(su)-
set bonding port tg.1.1 enable
SSA Chassis(su)-
set bonding enable
This command will reset the system and clear the current running configuration.
Are you sure you want to continue? (y/n)?
y
SSA Chassis(su)-
165
May 30 16:56:09 0.0.0.0 LinkTrap[2]Interface tg.2.1 is Up.
165
May 30 16:56:22 0
0
0
0 Bonding[2]Bond Link added port tg.2.1
165
May 30 16:56:23 0.0.0.0 Bonding[2]Chassis 00:1f:45:a1:18:0a added as a new member of bonded chassis 00:1f:45:fb:78:75 at index 0 slot 1.
165
May 30 16:56:33 0
0
0
0 Bonding[2]Bond Link removed port tg.2.1: probe loss
165
May 30 16:57:44 0
0
0
163
May 30 16:57:55 0.0.0.0 System[2]Module in slot 1 was replaced with a board of the same type. MAC=001f45a11809
165
May 30 16:57:58 0.0.0.0 System[2]Requesting a copy of the non-volatile store for slot 1.
163
May 30 16:57:59 0.0.0.0 System[2]Copying of slot 2's non-volatile storage to 1 complete.
165
May 30 16:57:59 0.0.0.0 System[2]The board in slot 1 of the chassis is operational.
163
May 30 16:57:58 0.0.0.0 System[1]Finished receiving a copy of slot 2's store.
163
May 30 16:57:59 0.0.0.0 System[1]Copying of slot 1's non-volatile storage to 2 complete.
163
May 30 16:57:59 0.0.0.0 System[2]Finished receiving a copy of slot 1's store.
show bonding
show config
configure slot1/fullConfig.txt append
Documentation
