SecureStack SNMP v3 "engine ID is not valid" error
‎12-27-2013 06:13 PM
Article ID: 11551
Products
SecureStack C3, C2, B3, B2, A2
Changes
Implementing SNMPv3 management of a stackable switch.
Configuring stackable switches with the (e.g. NetSight) SNMP server remote engineID.
Issued the '
Symptoms
CLI error message "
For example:
Cause
With some products this is optional, but the SecureStacks expect the remote engineID to be entered with a colon ("
Solution
Functions as Designed (FAD).
Type the command to include delimiting colons embedded within the remote engineID.
For example:
Products
Changes
Issued the '
code:
' command (e.g. 5390) to specify the remote engineID. set snmp user...
Symptoms
CLI error message "
code:
<Error, engine ID is not valid:
engineID>" is generated.
For example:
code:
>B3(su)-
set snmp user Myv3admin remote 811117e5807f4f1111d7f74f49 authentication md5 MyAuthPass privacy MyPrivPass
code:
Error, engine ID is not valid: 811117e5807f4f1111d7f74f49
code:
> B3(su)-
Cause
code:
") between each of its octets. :
Solution
For example:
code:
>B3(su)-
set snmp user Myv3admin remote 81:11:17:e5:80:7f:4f:11:11:d7:f7:4f:49 authentication md5 MyAuthPass privacy MyPrivPass
code:
B3(su)-
0 REPLIES 0
