set speed and duplex command
‎03-27-2014 02:24 PM
I'm looking for the command to set the speed and duplex on an Enterasys port (100mbps full and 1gbps full) does anyone know the syntax and/or able to give me an example or point me to a good resource? Thanks in advance
4 REPLIES 4
‎04-04-2014 04:06 PM
Go with Caution.
For 1000BASE-T auto-negotiation are mandatory.
From: http://en.wikipedia.org/wiki/Gigabit_Ethernet
Autonegotiation is the Requirement for Using 1000BASE-T [9] according to Section 28D.5 Extensions required for Clause40 (1000BASE-T). [10]
‎04-02-2014 02:31 PM
If you wanted to hard set a port to 100 meg full duplex you would issue the following 3 commands:
set port speed ge.1.1 100
set port duplex ge.1.1 full
set port negotiation ge.1.1 disable
‎03-27-2014 02:29 PM
Perfect. Thanks Tyler.
‎03-27-2014 02:27 PM
Hi Justin, I believe these are the commands you're looking for:
set port duplex ge.1.48 full
set port duplex ge.1.48 half
set port speed ge.1.48 1000
