Troubleshooting IP Default Gateway issues
‎11-05-2013 03:52 PM
Article ID: 5621
Protocols/Features
IP
PING
Tracert
Goals
Configure default gateway
Symptoms
Can't ping
"Destination Host Unreachable"
"Request timed out"
Incorrect default gateway
Cause
A ping response of "Destination Host Unreachable" is a solid indicator that there's a Default Gateway misconfiguration on the initiating PC.
A ping response of "Request timed out" could suggest a Default Gateway misconfiguration, but lower-layer (L1/L2) issues could also be in play.
Solution
Your choices for setting the Default Gateway are three in number:
Also available in GTAC Knowledge: "Troubleshooting IP Default Gateway issues".
Protocols/Features
IP
PING
Tracert
Goals
Symptoms
Can't ping
"Request timed out"
Cause
Solution
- No gateway IP - Conversations with other subnets will not take place. The host won't even write the packets to the wire.
Failure symptom: "Destination Host Unreachable"
- Gateway IP is pointed to the local router's local interface - Conversations with other subnets will be addressed to the router, as an intermediary device (Dest MAC = router; Dest IP = intended destination host).
Failure symptom: "Request timed out"
- Gateway IP is 'self-addressed' - All destinations will be treated as if local, so packet delivery relies upon either local presence of the destination host, or Layer 2 devices (bridges), or a router running Proxy ARP.
0 REPLIES 0
