AeroHive AP121 Firmware
EdP2
Hello!
I have acquired some AP121 units and I would like to manually update its firmware. How and where can I download the firmware files for it? I do not have a support contract for it.
Thanks in advance.
2 ACCEPTED SOLUTIONS
StephanH
Valued Contributor III
Hello Ed,
the AP121 is a cloud driven AP. The hole management and for example the softwareupdate is done via a cloud managment.
You can create an account here: https://extremecloudiq.com/entry
After first login you can choose a free account (=XIQ connect) with a smaller featureset.
Regards
Stephan
Regards Stephan
DominikM
New Contributor II
Hi All.
similar problem I have encountered. My 121's don't want to update from 6.4.1.0 through cloud. I have a plan to upgrade manually but I don't have access to firmware. Is there way out?
regards
Dom
5 REPLIES 5
toche
fffrr
DominikM
New Contributor II
Hi All.
regards
Dom
StephanH
Hello Ed,
Regards
Stephan
Regards Stephan
EdP2
Hi Stephan,
Thanks for your reply. Is there another way to update its firmware, like manual or offline update?
Thanks.
