Firmware on x 150,250
Gallo
hello community,
does anyone know what the small button on the back of the x 150,250,350 switches is for?
is it a simple reset?
does anyone know if there is a procedure to always reload the firmware in these switches?
Thank you
1 REPLY 1
Monaemma
The Reboot component of the organization gadget is helpful when certain progressions in the settings require a reboot to totally apply the setup settings, or on the other hand in the event that the gadget isn't working true to form. The setup settings of the organization gadget get reflected after the device restarts.
The Reset highlight is utilized to eliminate the running or current setup settings on the organization gadget and reestablish it to the first default settings. Manual reset is prescribed when the entire gadget should be reconfigured, or in the event that you fail to remember the secret phrase and are not ready to recuperate using any and all means, for example, getting to the control center utilizing Telnet or Order Line Connection point (CLI).
CVSHealthSurvey
