04-20-2024 11:16 PM
hello, i am using PuTTY to configure extreme switch, I want to know what is the method to save the switch configuration locally as notepad or something.
4 weeks ago
Which device model are you using? If it's an IQE device, I think the command is "show run config" and then you can copy that output in to your notepad draft. Is that what you're looking for?
