ā04-20-2024 11:19 PM
Hello,
I have 2 new extreme switches configured using PuTTY and want to make redundant to each other, what is the way to do that using the CLI?
Solved! Go to Solution.
ā04-29-2024 02:50 PM
Hi @azayer
Redundant in what terms? There are several possibilities.. Stacking might be the easiest, but I wouldn't recommend that for central switches. MLAG + VRRP is a simple and solid way that you could go.
Hi @azayer
