RADIUS Authentication Through NPS For B and C Series Extreme Switches
steve_zan
I'd like to setup RADIUS authentication through our NPS server for our B and C series switches. I have the configuration complete, on the switches. My issue is on the NPS server(specifically with the filter-ID). I see the request being passed to the NPS server, so I know that part is working. For the write-up, to configure the Extreme switches, at the very bottom it states:
"Additional notesThe policy on the RADIUS server must be configured to send back a filter-ID with the accept packet. See below for syntax and options.
Filter ID:
Enterasys:version=1:mgmt=access-mgmtType
Options:
access-mgmtTypes supported are: ro (read-only), rw (read-write), and su (super-user)."
Can someone explain this part to me? I think this is where i'm falling short....
Thanks!
1 REPLY 1
Sacha_Brys
Contributor
did you find a solution to your problem.
How did you setup the NPS then?
thanks in advance.
