How to get the possible port range on a switch within a script?
EtherNation_Use
Contributor II
Create Date: Jun 22 2012 2:04AM
Hi!
I want to write a script for Ridgeline that enables 802.1x on all ports that have MAC authentication enabled. The problem now is that I've following x450e setups:
    24 Port 48 Port 48 + 24 Port (stacked) 48 + 48 Port (stacked)
Whats the best way to get the port range used on this stack/switch so I can execute for example:
enable netlogin ports 1:1-48, 2:1-24 dot1x
Thx for your help.
(from Robert_Penz)
1 REPLY 1
EtherNation_Use
Contributor II
Create Date: Aug 3 2012 6:11AM
I would have a script parse through a "show config netlogin" command and grab all the ports with the "enable netlogin port mac". Once the ports are added to a list, then they can easily be added to a "enable netlogin ports dot1x" command.
(from john_padilla)
