ā12-07-2018 11:53 AM
ā02-15-2021 03:50 PM
But ācreate connect moduleā and āsend radius accountingā are two different questions⦠Thank you for request to clarification.
I am using āLightSpeed Systemsā connect module to send radius accounting messages to 3rd party solutions. The module sends the info if both IP and Username is known.
Proxy Radius Accounting (Radius server settings) is used only if Proxy to upstream Radius server is used (AAA rules)
ā02-15-2021 03:33 PM
thank you.
Just to prevent a misunderstanding, there is no other way to send only radius accounting information to other radius servers or devices like firewalls?
In NAC AAA you can define uplink radius servers and enable āProxy RADIUS Accounting Requestsā
But from my understanding I canāt use this, when my local control-engines handle the complete authentication process, right?
ā02-15-2021 02:20 PM
Hi PeterK
Connect modules are delivered/developed/maintained by Extreme. You can create your own āmiddlewareā that will use Connect or XMC through NBI.
ā02-15-2021 10:17 AM
Do we have any updates here regarding sso forwarding?
Is it now possible to create "connect modules" yourself? If so, is there any documentation?
