Study Guide
Study Guide
hafiz
Hi guys,
I'm a newbie in this extreme network product lines. I need your help/suggestion/guide. I need some reference books,guide,lab so that I can familiarize myself with the XOS command. Any suggestion?
Thank you so much in advance.
5 REPLIES 5
hafiz
other than that...is there any lab manuals that I can follow so that my personal training will be more effiecient?
hafiz
thanks for all the replies.my "extreme" journey will begin now 
Kevin_Kim
If you have a support portal account, we also can find e-learning courses in 'Training and Certifications' of 'my support' page
Below and more courses are available.
ExtremeXOS Fundamentals
ExtremeEOS Fundamentals
Drew_C
Valued Contributor III
Hi hafiz, welcome to The Hub!
In addition to the documents (and VM) Erik mentioned above, check out the EXOS Quick Guide.
Don't forget about the GTAC Knowledgebase.
You're welcome back here if you have any questions!
