Accessing An ExtremeXOS Switch When Admin Credentials Are Unknown
04-14-2015 12:32 PM
Forgotten passwords happen - Here's a helpful guide on EXOS password recovery. It will work on EXOS 12.1 or greater.
This procedure does not work for EXOS Summit switches with BootROM version 2.0.2.1 as the
1) Connect to the switch via serial console connection.
2) Power cycle the switch.
3) During the boot process, “hold the spacebar” to enter BootROM.
Extreme Networks
Alternate BootStrap Image
Starting CRC of Default image
Using Default image ...
Extreme Networks
Default BootLoader Image
DRAM Post
Press and hold the to enter the bootrom. 4) In the BootROM, enter the commands:
5) The switch should now boot to factory default settings. Login with the default credentials: admin/
6) From the prompt, use the vi editor to create and open a file entitled autoexec.xsf
vi autoexec.xsf
7) Then "
Then write the file with
9) Lastly, reboot the switch, not saving the configuration by typing
10) Login using the new account (test/test) from the CLI and make appropriate changes to the accounts to allow access (e.g. delete and recreate the admin account).
11) Delete the test account and the autoexec.xsf file.
delete account test
rm autoexec.xsf
--Thanks to Matthew Helm for putting this article together!
code:
command is not present in that BootROM version.config none
Extreme Networks
Extreme Networks
DRAM Post
Press and hold the
code:
config none
code:
boot
code:
login: admin
code:
password:
vi autoexec.xsf
7) Then "
code:
"nsert and type the following line, which will create a new user with admin privileges when executed.i
code:
create account admin test test
code:
^ESC :wq
code:
and typing "reboot
code:
" at any prompts. The commands within the autoexec.xsf file will be executed before the configuration file is loaded.n
delete account test
rm autoexec.xsf
1 REPLY 1
05-18-2016 02:18 PM
Thank you Drew, very helpful.
