AP Firmware Upgrade
  • 2
  • Question
  • Updated 3 months ago
  • Answered
I am using AP 7522E. This firmware version is 5.7.1.0-019R, i Want Upgrade to 5.8.0.0-050R using tftp. Shall i upgrade or Not. I tried using this command, device-upgrade load-image ap7522 tftp://<ip address>/AP7522-5.8.0.0-050R. but this status showing fail
where i did wrong?
Photo of Saravanamurthy K
Saravanamurthy K
  • 662 Points 500 badge 2x thumb
Posted 3 months ago
  • 2
Photo of Christopher Frazee
Christopher Frazee, Employee
  • 1,508 Points 1k badge 2x thumb
To upgrade the AP using TFTP, please use the following syntax from the CLI after successful login:
enable [enter]
upgrade tftp://ip_tftp/file_name [enter] (include extension)
Once file has completed upload to AP:
reload [enter]
AP will boot into new image.
If AP is a virtual controller and you wish to have adopted APs upgrade from the VC. The command you provided is what you would use and the file gets placed into the flash:/upgrade directory.
Photo of Bin
Bin, Employee
  • 5,350 Points 5k badge 2x thumb
Attache one KCS article for the reference
How to upgrade a WiNG controller or AP from CLI
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-upgrade-a-WiNG-controller-or-AP-fro...
Best regards
Photo of Timo
Timo
  • 3,210 Points 3k badge 2x thumb
 device-upgrade load-image -> this load the image into the flash for distributing, not to updates this AP.
As Christopher write, use "upgrade ..."
But also check the FW. You write it's a AP7522E (Express) but the image name show no E (for WING image). You need to use the Express image.
Photo of Christoph S.
Christoph S., Employee
  • 2,590 Points 2k badge 2x thumb
1 - Make sure you are using the correct image for the AP7522E. The file name used for this version is exactly the same as the one for the AP7522 so reverify.
2 - Make sure all the firewalls on the computer are off
3 - Run the following command:
(The file name is case sensitive. Don't leave out the file name extension)
upgrade tftp://<tftp server IP>/AP7522-5.8.0.0-050R.img
