AP3660 or AP3610 not password CLI
  • Problem
  • Updated 3 years ago
  • Solved
The AP3660 or AP3610 not access via CLI. With user: admin and password: new2day it was possible to access to configure witch cset dhcp disable, cset ipauthr and other. Now same Access Point is not possible, shows the prompt "(none) login: " This problem happens when Access Point is Sensor and was transformed to Access Point, go back.
When I follow the boot by cable console see several lines, between them: cp: cannot remove '/flash/home/config/shadow': No such file or directory.
I do not know the case of this problem, but I have to find out. I have some unsed AP.
Photo of Heraclito Junior
Heraclito Junior
  • 80 Points 75 badge 2x thumb
Posted 3 years ago
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 48,894 Points 20k badge 2x thumb
The prompt (none) login:  would indicate that the AP was switched to a HiGuard / WAS (Wireless Advanced Service) sensor and has a sensor software image installed
As far as I'd remember the login is config but I'm not sure about the pw, try also config.
The easy way to get back the AP software image is to connect it to the controller were the sensor was connnected to and switch it back to AP mode = the AP will load the AP image.
Heraclito Junior
Hi Ronald.
Thanks for response. I have 14 Wireless Controller instaled, is not possible found which W. Controller.
I tried the password config and user config but not is possible authentication.
My hope is resolution through Console port. I see these files and directories:
Boot-> ls
Scanning JFFS2 FS: . done.
 drwxr-xr-x        0 Sat Jan 01 00:31:58 2000 opt
 drwxr-xr-x        0 Sat Jan 01 00:00:22 2000 var
 drwxr-xr-x        0 Sat Jan 01 00:00:06 2000 home
 -rw-r--r--        0 Sat Jan 01 00:00:10 2000 .valid
 drwxr-xr-x        0 Thu Apr 25 17:23:40 2013 shared
 -rw-r--r--     7313 Sat Jan 01 00:00:16 2000 confData.bin
 -rw-r--r--     2979 Sat Jan 01 00:00:10 2000 boot_kernel.bak2
 -rw-r--r--     2979 Sat Jan 01 00:00:10 2000 boot_kernel.img2
 -rw-r--r--  3805184 Sat Jan 01 00:01:36 2000 sensor.gz.uImage
 -rw-r--r--  5265229 Sat Jan 01 00:03:59 2000 primary.gz.uImage
 -rw-r--r--  4141671 Sat Jan 01 00:02:30 2000 secondary.gz.uImage
is possible to recovery o AP3660 and 3610 with o Boot?
My client have 14 Wireless Controller and 500 Access Point
found a old mail its config/config
