ā07-18-2017 12:31 AM
I have an existing integration of EWC and Purview, however I went to use it today and it seems to have stopped working after I upgraded the analytics appliances to 8.0.2.42 a month ago. Some quick debugging hinted that while Netflix and mirrorN traffic was coming through, the appid process wasn't listening on the correct ports for some reason.
I figured it was then a good time to try and migrate to the new IPFIX-based method that doesn't need an L2 port any more. I followed https://extremeportal.force.com/ExtrArticleDetail?an=000090154 and set the Traffic Mirror L2 Port to None, and set traffic mirror to prohibited in all the VNS/Role configuration, but it's still not working. Anyone know what other configuration I need to set to make it use IPFIX?
ā07-18-2017 02:44 PM
ā07-18-2017 02:32 PM
Yep, going from EMC 8.0.3.46 to 8.0.3.53 fixed the issue here too. I actuall upgraded the Analytics engine first, but that wasn't enough.
I also found https://extremeportal.force.com/ExtrArticleDetail?an=000081442 which notes I was wrong to disable the traffic mirror and Netflow, all I needed to do was disable the traffic mirror L2 port.
