Chromecast not streaming over wireless ...
  • 2
  • Question
  • Updated 2 years ago
  • Answered
I'm using IdentiFi Wireless in my school district, how do I solve these problems:
- Chromecast is not streaming over wireless
- Chromecast utility is not able to locate the Chromecast device
Photo of Kaitlyn M.
Kaitlyn M., Extreme Alumna
  • 484 Points 250 badge 2x thumb
Posted 3 years ago
  • 2
Photo of Bob Nilsson
Bob Nilsson, Employee
  • 216 Points 100 badge 2x thumb
This can be caused by the UPNP Multicast group used by Chromecast not being permitted by default.
Enable multicast group on the wireless controller from the Web GUI with the following process:
Click Controller > Network > Topologies
Click the Topology Chromecast is connected to
Click Multicast filters tab
Click Multicast Bridging check box
Click IP group Radio button and add
Click Save
Photo of Kent Sapp
Kent Sapp
  • 260 Points 250 badge 2x thumb
Will this have any affect on any other wireless devices or will this only matter to the chromecast. I'm in the same situation and just want to make sure this won't mess up our laptops.
Photo of Raffi
Raffi, Employee
  • 1,598 Points 1k badge 2x thumb
The info is in the KB as well, pretty much what Rob said:
Chromecast is not connecting or streaming on IdentiFi wireless
Photo of Kent Sapp
Kent Sapp
I understand this will fix the chromecast issue. I just want to verify that enabling Multicast Bridging will not cause conflicts with other wireless devices on the network like laptops or phones.
Photo of Doug Hyde
Doug Hyde, Technical Support Manager
  • 19,730 Points 10k badge 2x thumb
If you are allowing a specific group like the article suggests vs ALL multicast then it should not cause issues, unless the rates for that group are high.
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 42,406 Points 20k badge 2x thumb
It's recommended to put that kind of devices in a dedicated VLAN/topology.
Here a link to the "The Extreme Networks Solution for Apple Bonjour Traffic Management"....
Because the setting is only enabled on this VLAN/topology the other VLAN/topology are not "affected".
