Configuration Netflow in S-Series does NOT Work
‎12-16-2014 10:30 AM
This is the configuration of my S-Series, however my collector receives no information, I do not understand what the problem is.
I monitor the collector with "tcpdump port 2203" but nothing is received, however if from the S-Series run telnet to 2203 if you get it, so I discard it a problem iptables.
Any ideas?
My configuration:
# Chassis Firmware Revision: 08.11.05.0007!
# netflow
set netflow export-interval 1
set netflow export-destination 192.168.8.82 2203
set netflow export-data enable vlan
set netflow port lag.0.121 enable both
set netflow template refresh-rate 600 timeout 1
set netflow cache enable
end
CPD1(su)->show netflow
Cache Status: enabled
Export Version: 5
Export Interval: 1 (min)
Number of Entries: 6291455
Inactive Timer: 40 (sec)
Template Refresh-rate: 600 (packets)
Template Timeout: 1 (min)
Destination IP UDP Port
10.0.0.10 2203
Export Rate Max Export Rate
Slot (records per second) (records per second)
2 10000 20000
3 10000 20000
Enabled Ports Both Ingress and Egress:
lag.0.121
Disabled Ports:
lag.0.1-120,122-127
ge.2.1-48,101-112,201-212
ge.3.1-48,101-112,201-212
Export Statistics:
Network Packets Sampled: 285574261
Exported Packets: 0
Exported Records: 0
Export Packets Failed: 0
Export Records Dropped: 0
Any ideas?
My configuration:
# netflow
end
Export Version: 5
10.0.0.10 2203
2 10000 20000
3 10000 20000
lag.0.121
Disabled Ports:
lag.0.1-120,122-127
Export Statistics:
Exported Packets: 0
Exported Records: 0
2 REPLIES 2
‎12-17-2014 09:35 AM
it work!
A default interface must be configured for the records to export.
"set ip default interface vlan.0.1"
My S4 vlan.0.1 not exist, I have defined another interface and started to work.
Thanks GTAC.
Thanks GTAC.
‎12-16-2014 01:54 PM
I have seen a similar problem.
We have a number of S series devices exporting flows successfully.
However the switch the netflow collector is attached to does not send out any flows despite all S series have an identical netflow configuration.
If i run wireshark on the collector i can see flows from all other switches, but not from the switch it is attached to.
I meant to speak to GTAC about it but have not had time yet.
Thanks,
Mark.
Thanks,
Mark.
