DHCP Standard Practise
  • Question
  • Updated 3 months ago
  • Answered
I have a question regarding DHCP.
Whats the standard practise for implementing DHCP helpers.
Our current setup, we use UDP profile on all our vlans on our core switches that require dhcp services. this is an inherited design before my time.
would it be more beneficial to go down the bootprelay route?
are there any other options? pros and cons for each?
Many Thanks
Ian
Photo of Ian Broadway
Ian Broadway
  • 1,662 Points 1k badge 2x thumb
Posted 2 years ago
Photo of OscarK
OscarK, ESE
  • 7,792 Points 5k badge 2x thumb
In early days UDP helper was the only method to be able to distinguish between vlans and DHCP servers.
Nowadays you can enable bootprelay per vlan so you can use bootprelay without enabling it for all vlans. Still I think if you need different DHCP servers for different vlans UDP profile is the only config possible.
Ian Broadway
We use 2 DHCP servers for all our vlans, I assume you can specify more than one server within the bootprelay config?
Photo of Jarek
Jarek
  • 2,398 Points 2k badge 2x thumb
For example rel. notes 15.6 says that the maximum number of BOOTP or DHCP servers per virtual router is 4
Jarek
Photo of Jarek
Jarek
Ian, it depend what you need :).
Oscar, I think you can use bootprelay with more  DHCP servers, with additional config on server: agent.circuit-id, agent.remote-id, class, allow members of ... and so on.
It will respond only to configured "class members".
Jarek
Ian Broadway
the scenario is, we have two DHCP servers and I would like all DHCP requests for 20 VLANs to go to these servers.
is it a case of;
configure bootprelay add "DHCP Server IP 1"
configure bootprelay add "DHCP Server IP 2"
configure bootprelay vlan "vlan 1"
configure bootprelay vlan "vlan 2"
and so on.
(Edited)
Photo of Jarek
Jarek
Simpler:
1) confgure bootprelay servers
configure bootprelay add 1.1.1.1 vr VR-Default
configure bootprelay add 2.2.2.2 vr VR-Default
2)  enable bootprelay
enable bootprelay  - "Enables the BOOTP Relay function on  all VLANs"
"If DHCP/BOOTP Relay is enabled on a per VLAN basis, make sure it is enabled on both theclient-side and server-side VLANs."
Jarek
Ian Broadway
I was going to say, not every vlan is DHCP serviced so would i stick with my example?
Photo of Jarek
Jarek
disable bootprelay vlan XXX
Jarek
Photo of Jason Grubbs
Jason Grubbs
  • 60 Points
I know this is an old post, but would this configuration still be the same when working with dhcp servers in a load balancing configuration (windows server 2016)?  List both servers?  Does it matter which one is first?
