ECA - how to add a switch
  • Question
  • Updated 1 week ago
  • Answered
How could I tell my 220 switch to connect to my ECA.
I'm running latest software so that is OK but I can't find how I'd tell the switch the IP of the ECA via CLI or GUI.
I wasn't able to find any user manual for the 200series on the webpage to check whether that includes some information.
Thanks,
Ron
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 49,972 Points 20k badge 2x thumb
Posted 1 week ago
Photo of Doug Hyde
Doug Hyde, Technical Support Manager
  • 20,606 Points 20k badge 2x thumb
Take a look at the help file in the ECA...
Adding a Switch Access Points and Switches are automatically added to via the cloud-connector when the DHCP and DNS prerequisites have been met. You can use the Add functionality to pre-provision any AP or switch before they connect.
To add a switch to your network:
  1. Per-configure your external DHCP and DNS servers on your network for discovery of the new switch. In order for the to communicate to the ExtremeCloud Appliance:
    • The DHCP Server (that will be serving an IP to the switch) needs to return a DNS Server and Domain Name to the switch.
    • The DNS Server needs to map the name extremecontrol. to the IP address of the ECA that you plan to add the switch.
    • Confirm that the DHCP server is serving the correct DNS and domain name information.
  2. Go to Devices > Switches.
  3. Click Add and configure the parameters. NOTE
    You can clone a switch from within a site, see Switches
  4. Configure the following parameters.Serial NumberUnique number that identifies the switch. Provide this number for new and cloned switches. This number is on the switch.ModelSelect model number from the drop-down list. The model number is on the switch.NameUnique name for the switch. Provide a unique name.DescriptionText description to help identify the switch.
  5. Click OK.
  6. Connect your switch to the network and power it on. NOTE
    The switch must be reset to factory default configuration. Refer to the switch documentation to reset your switch to factory defaults.
Related TopicsSwitch Actions
Configuring a Switch
(Edited)
Doug,
my ECA config is fine but I'd like to know whether there is no option to just configure the IP of the ECA via the 220 CLI/GUI instead of using DHCP ?
Thanks,
Ron
Photo of Bastian Sprotte
Bastian Sprotte, Employee
  • 1,660 Points 1k badge 2x thumb
Hi Ron,
on the 200-Series you can just add an host entry,
(Extreme 200) # ip host "extremecontrol" <eca_ip_address>
regards,
Bastian
Photo of Doug Hyde
  • 20,586 Points 20k badge 2x thumb
Thank you, sir!
Hey Bastian,
that did it - thanks a lot !!!
Cheers,
Ron
Photo of Doug Hyde
