ELRP and STP x450e
  • Question
  • Updated 3 years ago
  • Answered
  • (Edited)
I have 1 x450e acting as a core switch and 5 more that are trunked to the core; a basic hub and spoke topology. I don't believe there is a loop in this design, but my question is do I need to run STP or ELRP here? Can someone give me some best practices as it relates to preventing loops or other issues with this topology?
Thanks
Photo of Andrew S.
Andrew S.
  • 210 Points 100 badge 2x thumb
Posted 3 years ago
Photo of Patrick Voss
Patrick Voss, Employee
  • 11,474 Points 10k badge 2x thumb
Hi Andrew,
with a hub and spoke setup STP should not be required but it really is a matter of opinion. If the setup is all Extreme then ELRP will work just fine. Here is an article that provides a basic configuration for ELRP:
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-configure-ELRP-to-disable-ports
Hope this helps!
Photo of David Coglianese
David Coglianese, Embassador
  • 5,944 Points 5k badge 2x thumb
Andrew,
If it is a hub and spoke design I would:
create vlan "noloop" and add it to every port tagged
Add all your uplink ports to the elrp excluded list on their respective switches. In our designs configure elrp to permanently disable ports when a loop is detected.
This will protect you from people plugging loops in and prevent your uplinks from being taken down by the loop.
Photo of Andrew S.
Andrew S.
Thanks for the quick reply. I did see the article on ELRP; another question on that, do I apply it only on the uplink from the access switches or just the ports on the core that the access switches trunk too or both?
Sorry, for the basic questions, I'm a bit new to this.
Thanks.
Photo of Andrew S.
Andrew S.
I think I know the answer to that, but to confirm. I set ELRP on all ports and disable it on the uplink on all switches????
It is recommended to apply ELRP on all the ports in each VLAN then exclude the uplink ports. I would do this on ALL switches because it will be easier to track down where the loop is if there is one.
You would want it on both ends of the link. Any port with the vlan you are using will get disabled unless it is on the excluded list.
Photo of Andrew S.
Andrew S.
Perfect, thank you for confirming that, and thank you for the assistance.
Photo of Bill Stritzinger
Bill Stritzinger, Alum
  • 6,016 Points 5k badge 2x thumb
Andrew,
ELRP goes great on the edge facing ports, it is simple to monitor and simple to configure and works great.  All you would do is enable ELRP on the vlans (must configure for each vlan if tagged) and ports pointing toward your edge devices, the only real decision is what you want to do when a loop occurs, your options are:   1. take no action and log; 2. log and disable port permanently; 3. log and trap and disable port for a duration time and any combination in between.  In most cases like a education installation we will disable port permanently so the admins have to take action and manually re-enable the port(s).  The best thing about ELRP is its ability to find a loop several switches down, something STP Edge Safeguard cannot do.
Here is a link to the user guide regarding detailing more info and configuration examples: http://documentation.extremenetworks.com/exos/EXOS_All/Troubleshooting/t_configure-standalone-elrp.s...
