Extreme Summit X440 to Cisco Catalyst C2960X Spanning tree
  • Question
  • Updated 3 years ago
  • Answered
  • (Edited)
Hi.
I need to add and connect a X440 stack to an on-production Cisco switch ring.
Somebody can help me to know the right spanning tree configuration for the X440 to be compatible with the existing Cisco spanning tree configuration?
This is the spanning tree an uplink interfaces config at the Cisco switches:
spanning-tree mode rapid-pvstspanning-tree loopguard default
spanning-tree portfast default
spanning-tree extend system-id
spanning-tree vlan 1-4094 priority 61440
interface GigabitEthernet1/0/25
 switchport mode trunk
 switchport nonegotiate
 load-interval 30
 storm-control broadcast level 30.00
end
interface GigabitEthernet1/0/26
 load-interval 30
end
Exos version: 15.3.1.4
Thanks!
Photo of Edgar Dattoli
Edgar Dattoli
  • 230 Points 100 badge 2x thumb
Posted 3 years ago
Photo of Dorian Perry
Dorian Perry, Employee
  • 2,302 Points 2k badge 2x thumb
Hi Edgar,
Here is a sample EXOS configuration that should work with what you have on the Cisco Side:
#Extreme Configuration (EXOS)#
conf vlan default delete port 1,3
create vlan test
config vlan test tag 10
config vlan test add ports 1,3 tagged
disable edp port 1,3
create stpd domain_test
conf stpd "domain_test" add vlan "test" ports 1,3 pvst-plus
conf stpd "domain_test" tag 10
configure stpd "domain_test" mode dot1w
conf stpd "domain_test" default-encapsulation pvst-plus
conf stpd "domain_test" ports link-type point-to-point 1,3
enable stpd "domain_test"
Edgar Dattoli
Hi Dorian, and thanks for the reply.
Some questions:
1. The Extreme pvst-plus is compatible with the Cisco rapid-past?
2. About the sample, the what is the VLAN 10?
3. I must create a stpd domain for each VLAN y my network?
Bests
1.Yes the Extreme XOS configuration I provided is compatible with "spanning-tree mode rapid-pvstspanning-tree" on the Cisco side.
2. VLAN 10 in the example is the carrier VLAN for STPD "domain_test".
3. You should be able to add additional VLANs to same stpd using the command:
configure stpd "domain_test" add vlan <VLAN_NAME> ports <PORT_LIST> pvst-plus
Edgar Dattoli
a) then if I have 25 vlans, I can use your example config and just add a line 'configure stpd "domain_test" add vlan' for each of the 25 vlans. Right?
b) The parameter <PORT_LIST> refers to the uplink ports?
a) Yes that should work
b) Yes these would be the uplink/ring ports
Edgar Dattoli
Must I create the VLAN 10 (carrier VLAN) on all the CISCO Switches, or just in the CISCO Switches near to the X440 (Neighbors) ?
VLAN 10 does not need to be created at all. The carrier VLAN can be an existing VLAN of your choosing.
See GTAC Knowledge article: What is a STP Carrier vlan?
Edgar Dattoli
Must I specify the carrier VLAN at the Cisco configuration?
