Fan Monitoring
  • Question
  • Updated 3 months ago
  • Answered
  • (Edited)
We need to monitor the fans of 31 Extreme switches in our network using NPM.
The OID that I used to monitor the fans is "1.3.6.1.4.1.1916.1.1.1.9.1.2" and the result always "1" even when there is a fan fault.
We have a switch the fan LED is blinking orange. I tried to check the fans status directly from the switch using "show fans" I have found 6 fans in this switch one of them is not operational the RPM was zero.
So how we can monitor each fan in each switch to get the correct result that indicates that the fan working well or not.
Photo of maani
maani
  • 80 Points 75 badge 2x thumb
Posted 3 months ago
Photo of Stephen Williams
Stephen Williams, Employee
  • 8,908 Points 5k badge 2x thumb
I would setup a trap receiver, and look out for the below trap.
Name extremeFanfailed
OID .1.3.6.1.4.1.1916.0.7
MIB EXTREME-TRAP-MIB
Objects sysUpTime, sysDescr, extremeFanNumber
Description:  A fan failed trap indicates one or more of the cooling fans inside the device has failed. A fanOK trap will be sent once the fan has attained normal operation.
(Edited)
Photo of maani
maani
Thanks Alot.
I will create a new trap for this.
But for what is this OID "1.3.6.1.4.1.1916.1.1.1.9.1.2" used ??
