Flow redirect with ECMP
  • Question
  • Updated 1 year ago
  • Answered
I have checked the doc. and so on... but didn't find answer to my question.
Is it possible to do ECMP with flow-redirect ?
I have config like bellow:
- 2 default gatways with the same metric
configure iproute add default 1.1.1.1 100
configure iproute add default 2.2.2.2 100
- I have enabled iproute sharing
The traffic is equally send through 2 GW's.
I use also flow-redirect with prio 150 to send traffic from 10.0.0.0/24 via 192.168.1.1
And that is working fine.
My goal is:
I want to add a second flow-redirect with prio 150 to send traffic from 10.0.0.0/24 via 192.168.1.3
and have ECMP from 10.0.0.0/24 via192.168.1.1 and 192.168.1.3
Is it possible to achieve this ?
Jarek
Photo of Jarek
Jarek
  • 2,398 Points 2k badge 2x thumb
Posted 1 year ago
Photo of Brandon Clay
Brandon Clay, Escalation Support Engineer
  • 13,606 Points 10k badge 2x thumb
Hi Jarek,
No, this is not currently supported in EXOS. Flow-redirect only allows one next-hop per priority value.
Photo of Jarek
Jarek
Thank you for answer Brandon.
Are there any chance to add this feature to 15.X or 16.X branch?
Jarek
