Getting clean output from Extreme switch CLI using Python
  • Question
  • Updated 12 months ago
  • Answered
I am writing a python script to run some show commands on Extreme switches and storing output in a variable.  I am able to accomplish that but the output is not as I would like.  I am seeing the command and also switch name in my output but I would like to just see the result of my show command and nothing else.
This is what I am seeing:
print "ISC Port is: ", ISC
ISC Port is: sh vlan ISC | i Tag:
       Tag:      1:1g
Ext-SW1.com.5 #
This is what I would like to see:
ISC Port is: Tag:      1:1g
Here is my code where I am reading output:
ISC = "sh vlan ISC | i Tag:"
tn.write(ISC + "\n")
idx, obj, output = tn.expect(["\.\r\n\r\*"], int(timeout))
print "ISC Port is: ", output
How do I get rid of device name and my commands from output to show only output.  I played around with "read_until" but can't seem to get it cleaned up.  Example:
tn.read_until(".2 #")
Any help will be appropriated.
Photo of Marvel King
Marvel King
  • 90 Points 75 badge 2x thumb
Posted 1 year ago
Photo of Dave Hammers
Dave Hammers, Dir SW Engineering
  • 3,782 Points 3k badge 2x thumb
If the switch is running EXOS 21.x or later, you could use JSONRPC instead of screen scraping the telnet display. An example script is here: https://github.com/extremenetworks/ExtremeScripting/tree/master/EXOS/Python/jsoncli
Photo of Grosjean, Stephane
Grosjean, Stephane, Employee
  • 13,672 Points 10k badge 2x thumb
As Dave mentionned, if you are running 21 or later, you really should consider JSONRPC.
Marvel King
No, we are running 15.x.
Photo of Brandon Clay
Brandon Clay, Escalation Support Engineer
  • 13,486 Points 10k badge 2x thumb
Since JSONRPC isn't available, I'd probably use regex to pull out the specific part you are looking for. I put together a quick example below:
import re
output = 'sh vlan ISC | i Tag:\nTag:     1:1g\nExt-SW1.com.5 #'
p = re.compile('(Tag:\s*\d:\dg?)')
m = p.search(output)
output = m.group(1)
print output
This won't work for non-stacks, but it should give you an idea.
And for what it returns:
bash-3.2$ python regex.py
Tag:     1:1g
(Edited)
Marvel King
I am already using regex to extract what I need but I was hoping there is a cleaner way.  My regex is not pretty due to all extra junk I am scrapping.
Photo of Ed McGuigan
Ed McGuigan
  • 500 Points 500 badge 2x thumb
It's important to be using a good regex tool to cut down time on developing the right regex. There are lot's of good tools out there. I paid for an app regexbuddy but there is also https://regex101.com/ that has python support and a very nice interface.
