GUI Interface on AP7522E
  • Question
  • Updated 8 months ago
  • Answered
I am unable to connect to the GUI on the access points connected to a VC, i can connect to the VC but one of the installation tests that we carry out is ensuring that we can browse to the non VC access points. It is an Express access point installation the firmware level is 5.8.5.0-016R
Photo of James Forsyth
James Forsyth
  • 70 Points
Posted 1 year ago
Photo of Dimitri Corzano
Dimitri Corzano, Employee
  • 90 Points 75 badge 2x thumb
Once AP is adopted to controller or Virtual controller, UI access to AP  is disabled..  this is by design.
Photo of Darrel Rhodes
Darrel Rhodes, Employee
  • 1,186 Points 1k badge 2x thumb
Hi James,
I'm running a VC network using WiNG AP7622s.
I can connect to any of the APs providing I force a HTTPS connection. HTTP just times out.
Have you tried HTTPS?
Many thanks,
Darrel.
Photo of Andy Holden
Andy Holden, Employee
  • 1,492 Points 1k badge 2x thumb
When an Express AP is adopted to a Controller/VC, it assumes the adopted APs will be managed by the controller. By design, any GUI access will be redirected back to the Controller/VC. Although you cannot access the individual APs GUI interface, you can access the APs CLI interface
Photo of Andrew Webster
Andrew Webster
  • 1,878 Points 1k badge 2x thumb
James, If the purpose of the test is to verify connectivity to the other APs, then the simple fact that they are adopted should be good enough.
Photo of Robert Zarzycki
Robert Zarzycki, Employee
  • 4,930 Points 4k badge 2x thumb
Alternative test that can be done on the adopted APs is a CLI connectivity.
Photo of Christoph S.
Christoph S., Employee
  • 3,450 Points 3k badge 2x thumb
Bear in mind that you cannot make any config changes to Express APs from CLI.
(Edited)
Photo of Daniel Mejia
Daniel Mejia, Employee
  • 1,056 Points 1k badge 2x thumb
APs adopted by a VC are to be managed by the VC. Therefor GUI access to adopted APs is disabled.
Photo of Douglas Novell
Douglas Novell, Employee
  • 506 Points 500 badge 2x thumb
Just to add you can check the status of the adopted APs from the VC by going to Configuration-Access Points. This should list all of the APs adopted and their 'online' or 'offline' status.
Photo of Mevan Liyanage
Mevan Liyanage
  • 120 Points 100 badge 2x thumb
you can re enable it using CLI
