How send a SNMP Traps test to the Network Management?
  • Question
  • Updated 1 year ago
  • Answered
Hi All,
I am working on the integration of Extream Network 450a switch to the Network Management system, the integration is already done, but we want to make some test, Can you please let me know how can I test this traps?
Thank you so much in advanced
Luis Melendez
Photo of Luis Melendez
Luis Melendez
  • 142 Points 100 badge 2x thumb
Posted 1 year ago
Photo of Ram
Ram, Employee
  • 1,450 Points 1k badge 2x thumb
Please log into the switch and type in the following command:
“configure snmp add trapreceiver <Server_IP_Address> community <Community_Name>”
If no SNMP trap receiver is configured, EXOS will not send traps. Use command "show configuration snmp" and "show management" output to see the trap receiver is configured.
Photo of Ram
Ram, Employee
Use the command "show management" and check the counter "SNMP traps" is increased.
Please use the below url to download the MIB Browser Personal Edition (3rd party):
http://www.ireasoning.com/download.shtml
After installing, go-to tab Tools -> Trap receiver -> then initiate a port UP/DOWN from switch trap and you will see the SNMP traps in ireasoning tool.
Luis Melendez
Hi All, Thank you so much for your answers.... The SNMP configuration on the switch is done, I am looking for a way to send a trap for test.
Best Regards
Luis Melendez
Photo of Bin
Bin, Employee
  • 5,370 Points 5k badge 2x thumb
Hello Luis,
Are you using Extreme Management Center as Network Management system?
If yes, you could reference to the following script
Netsight: How to configure a summit switch to send a SNMP v3 trap to Netsight, and have Netsight correctly log the trap for that switch
https://gtacknowledge.extremenetworks.com/articles/How_To/Netsight-How-to-configure-a-summit-switch-...
Best regards,
Bin
Photo of Karthik Mohandoss
Karthik Mohandoss, Employee
  • 5,998 Points 5k badge 2x thumb
Hi Luis,
Please see if this command works for you.
create snmp trap severity info event test "this is a test trap"
Photo of Brad Parker
Brad Parker, Technical Support Engineer
  • 3,500 Points 3k badge 2x thumb
Hi
Please use the "create SNMP trap" command. I think this is what you're looking for
Thanks
Brad
Luis Melendez
GREAT!!! this is that we need !!! Thank you so much!!!
Photo of Bin
Bin, Employee
