How to bind a Custom FlexView in to Oneview Device View
_up__bb_
New Contributor III
I created my custom FlexView, now I would like to apply this flexview to a specific device,
so I can see the information about these flex on the Device View of the OneView.
How I can set up this binding?
Thanks
Roberto
20 REPLIES 20
Visconti
New Contributor III
Goooooddddd !!!!!
Thanks a lot !!!!
Very very good !!!!
Visconti
New Contributor III
Hi ZdeneK,
when I use your fantastic flexview learned mac addresses with ALIAS and I tray to create a group in the left of the screen Extreme show me the string like in the left but would be great if the system showed me the alias of the pc (orange arrow in the right side)
So...
could you replace the string on the left side with the description of pc show in the right side (ifAlias) ?
the flexview is only the content of the right hand side of the screen. Flexview can be modified. The left hand side with device tree is not something you can modify.
These strange numbers are instance numbers the switch reports for the MAC address table.
Sorry. can not help with this request.
Z.
Regards Zdeněk Pala
ok thanks a lot..but it's a pity not to see the alias field
