How to create a Guest SSID in Enterasys controller C5210?
Laura4
New Contributor II
I need help in creating a Guest SSID in our network, so the user can only get on the internet. I also want them to have to login, or enter an email address. And do not broadcast the Guest SSID.
Can someone help me?
6 REPLIES 6
hsachse
New Contributor III
Hello Laura,
this youtube video describe how you could create a guest SSID:
https://www.youtube.com/watch?v=PsjF_loI-xA
More advanced guest portal features are includee in the Extreme NAC solution.
Hi Will,
were you able to solve the problem.
Could it be that you try to use the address 172.31.0.x - the controller uses 172.31.0.16/28 for internal services so you can't use that one.
https://gtacknowledge.extremenetworks.com/articles/Solution/IdentiFi-Wireless-Controller-does-not-al...
-Ron
Do you know where I can get more information? I'm getting a IP address conflict which is strange because it's a subnet that is not being used anywhere. This is so overly complicated. Sheesh.....
