How to switch Ap7562 wing to wing express interface
  • Question
  • Updated 11 months ago
  • Answered
Hi everybody
I changed interface AP7562 from Wing Express to Wing interface. How to revert to Wing Express and Ap7161 have Wing Express?
Thanks
Photo of Tuan Nguyen
Tuan Nguyen
  • 678 Points 500 badge 2x thumb
Posted 11 months ago
Photo of Timo
Timo
  • 3,210 Points 3k badge 2x thumb
I think you mean the SWIFT UI and not the Express AP Version? To change the UI back, you need to do a factory reset. I think there is no other way.
Photo of Orson Joseph
Orson Joseph, Employee
  • 240 Points 100 badge 2x thumb
Hi
The feature to switch UI interfaces is only available with APs using the Swift UI. Swift UI APs interface and the Express APs interface looks exactly the same. The difference can be notice in the model name of the AP. Express APs have an “E” at the end of the name, ex. AP7522E. But the only way to go from enterprise UI to Swift UI is to factory default the AP.
Tuan Nguyen
Thanks Orson Joseph
Ap7161 can switch to Swift UI ?
Photo of Bin
Bin, Employee
  • 5,350 Points 5k badge 2x thumb
From WiNG Express User Guide, it looks that we did not support 7161 on WiNG Express.
WiNG Express Access Point portfolio consists of two dual radio 802.11ac Access Points (AP7502E and AP7522E) and four 802.11n Access Points (AP6511E, AP6521E, AP6522E and AP6562E).
http://documentation.extremenetworks.com/WiNG/5.9.0/9035125_WiNG_Express_5_9_UG.pdf
Best regards,
Bin
Photo of Andy Holden
Andy Holden, Employee
  • 1,092 Points 1k badge 2x thumb
The feature to change from the SWIFT to the Enterprise interface is only available on the 75XX Enterprise series of APs. And yes, the only way to go back to the SWIFT interface is to factory Default the AP. This is because changes can be made while in the Enterprise interface that are not compatible in the SWIFT interface
