How to use ZTP+
  • Question
  • Updated 9 months ago
  • Answered
Hello Community,
I'm currently trying to set up a ZTP+ staging area in our testlab.
So far I've set up the DHCP-Server and DNS-Server. I know that the Switch (Summit x450-G2 Fw: 22.3.1.4) gets an IP and can reach the EMC ( Fw: 8.0.3.53). In the Discovered-Tab I can only see the Switch via normal ZTP but not ZTP+. I tried to pre-register the Device but that didn't help. Did I forget to do something?
In the EMC User Guide it says, that I have to enable ZTP+ for the Site I'm adding the Switches.
But the Enable ZTP+ checkbox under the Discovered Device Actions-Tab is missing.
Could someone please help?
Thanks in advance,
Michael
Photo of Michael Eisenschmid
Michael Eisenschmid
  • 132 Points 100 badge 2x thumb
Posted 9 months ago
Photo of Charles Bickford
Charles Bickford, Employee
  • 100 Points 100 badge 2x thumb
Make sure your DNS server maps extremecontrol to the IP of EMC. Also make sure the summit switch has no configuration so that the ztp+ process begins. If you are seeing it show up via ztp, it would be useful to remove the DHCP options for ztp from your DHCP server. This will ensure the summit keeps retrying via ztp+.
Photo of Bharathiraja, Suresh
Bharathiraja, Suresh, Employee
  • 3,442 Points 3k badge 2x thumb
Hi Michael,
I hope below KB will help you to for further debug on ZTP+.
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-troubleshoot-and-debug-ZTP-on-Extre...
Thanks,
Suresh.B
Photo of Karthik Mohandoss
Karthik Mohandoss, Employee
  • 5,468 Points 5k badge 2x thumb
Michael Eisenschmid
Hello Guys,
Thank you all for your replies.
@Charles Bickford
I'm only using Options for the Default Gateway, DNS-Server and Domain-Name. I don't use Option 43 or 125.
@Bharathiraja, Suresh
In the Server.log file there was only this one line written:
2017-09-12 09:09:00,271 ERROR [com.ets.netsight.inv.server.webapps.monitor.InventoryDwr] Error retrieving Device Records for DeviceType: null ex:null
which lead me to the following KB article:
https://gtacknowledge.extremenetworks.com/articles/Solution/Unable-to-find-Saved-device-configuratio...
Since this is about ZTP and not ZTP+ I think I can ignore this Error.
@Karthik Mohandoss
I should have done everything according to this article.
I Pre-registred the Device but in EMC the Status field in the Discovered Tab won't Change form ZTP+ Staged.
Kind Regards
Michael
Photo of Stephen Williams
Stephen Williams, Employee
  • 8,838 Points 5k badge 2x thumb
The article was was for ZTP and ZTP+  I would upgrade netsight.
I updated the article.
(Edited)
Hi Michael,
Thanks for your update,
Thanks,
Suresh.B
Michael Eisenschmid
Hello Guys,
here another update:
I managed to discover a device with ZTP+ I think by changing the Poll Type from SNMP to ZTP+ under Network>Devices>World>ZTP+DeviceDefaults.
I was unsure how I did it so I wanted to try again and issued the "unconfigure Switch all" Command in the CLI. In the User Guide I read that no Console cable may be connected to the device otherwise ZTP+ Transaction would fail so I removed the cable from the console port while still having one cable connected to the DNS-/DHCP-Server and EMC while the Switch restarted. But after that I still had the same issue as explained above.
Kind regards
Michael
Photo of Grosjean, Stephane
Grosjean, Stephane, Employee
  • 12,532 Points 10k badge 2x thumb
Poll type set to ZTP+ will work only if you are running CC 3.0, version that you need to install in the firmware tab of EMC 8.0. You can download it from Extreme github. Please note, CC 3.0 doesn't work with EMC 7.0 and before.
CC 3.0 is not required for ZTP+ to work. EXOS includes a version of CC natively (1.x - depends on EXOS version) since 21.1 to perform the ZTP+ feature.
if you confirm that:
- the switch is in factory default
- it's not a stack
- it runs at least 21.1
- there's no default.xsf nor autoexec.xsf files
- it can reach DHCP, have an IP and DNS options
- it can reach DNS to resolve extremecontrol (IP of EMC)
then you need to connect to it, go under the cc_logs directory (cd cc_logs), and upload the files you should find there. They should tell what is going wrong.
Photo of Bin
Bin, Employee
  • 5,350 Points 5k badge 2x thumb
