Questions and discussions about ExtremeCloud IQ-Site Engine Management Center
Policy Manager XMC
Good Morning, a Customer ask if is possible to use XMC Policy Manager without NAC and radius. At the moment is necessary check the OUI and put on a correct VLAN. I configured X440 in CLI and it works, now we want to do the same with XMC.   Thanks Giu...
RADIUS Proxy Via NAC Eth1
Hi, To keep it as simple as I can……. Have a scenario where the NAC Eth1 and EWC ESA1 both exist in the DMZ. The solution requires a captive portal that I am intending on presenting via NAC with ‘Authorised Registration’ that uses proxy RADIUS to auth...
Anonymous by • Not applicable
  • 1874 Views
  • 3 replies
