How upgrade BD8810??
  • Question
  • Updated 2 years ago
  • Answered
Hello. Do I upgrade a BD8810 like Summit Xos ??
Photo of Angel Pavon
Angel Pavon
  • 544 Points 500 badge 2x thumb
Posted 2 years ago
Photo of Brian Austin
Brian Austin, Employee
  • 452 Points 250 badge 2x thumb
Hello Angel,
I believe this article will be able to help you on how to upgrade your BD.
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-Obtain-and-Upgrade-EXOS/?q=how+to+u...
Angel Pavon
thanks a lot. Brian
Photo of Patrick Voss
Patrick Voss, Alum
  • 11,594 Points 10k badge 2x thumb
Hello Angel,
The process is the same. It will push the image to the other MSM and the slots automatically. There may be an extra step involved but this will present itself in the CLI or in the logs.
Angel Pavon
Thank you Patrick.
Photo of Tripathy, Priya Ranjan
Tripathy, Priya Ranjan, ESE
  • 2,306 Points 2k badge 2x thumb
While upgrading any Black Diamond chassis with 2 MSMs execute the given steps provided in the above article which would automatically synchronize with the back up MSM. Hence it is not necessary to specify the partition on which to load the new image.The reason being  by default it will be downloaded and installed on the non-active partition always.
