Howto add multiple VLAN over MPLS VPLS connection
  • Question
  • Updated 2 years ago
  • Answered
Is it possible to create multiple VLAN over my MPLS VPLS over VMAN. My end to end connection between my two peer are now established. What should I do to have my VLAN at my other end pass through over my MPLS.
Thank you in advance.
Photo of jaros
  • 120 Points 100 badge 2x thumb
Posted 2 years ago
Photo of Paul Russo
Paul Russo, Alum
  • 9,694 Points 5k badge 2x thumb
Hello Jaros
Is the MPLS network yours (i.e. you created it with your gear) or is it something that is provided to you from a Service Provider?
You can absolutely create multiple VLANs across your VPLS network, It is a little tricky have you read the Concepts guide on VPLS yet?  That will give you a good start in understanding the concepts and the commands that are needed.  I will start there and either come back to the Hub for fine tuning the solution or look within our Knowledge base to see if there is already a post on creating VLANs over VPLS network.
