inter-vlan routing between stacked and standalone x450e switches
  • Question
  • Updated 4 months ago
  • Answered
I have an existing stack for the access layer and want to add a TOR switch.
All x450e 12.6.2.12
configured vlans to match the stack
removed all ports from default vlan(matching the old stack)
enabled IP forwarding
routes show the existing stack vlan gateways and the new interface ips for the vlan
I didn't really want to assign IP address to the vlans on the new TOR switch, but it seemed to be required.
I believe I am missing a key concept on how vlan does its routing(am cisco guy, this is my first extreme shop), does anyone know of a good guide/cookbook to config this specific scenario?
I feel like I should add the vlan gateways from the stack, and be good to go... but that failed on my first go.
Photo of Charles Cox
Charles Cox
  • 90 Points 75 badge 2x thumb
Posted 4 months ago
Photo of David Coglianese
David Coglianese, Embassador
  • 7,128 Points 5k badge 2x thumb
There are sort of a lot of questions here. But your Core, or Router/Routers should be doing  the routing. If all VLANs (VLAN tags) match are are added tagged on both ends of the uplink you should have layer 2 connectivity.
Typically I would add a NetMgmt VLAN with an address to reach and manage the TOR switch, no other VLANs would have IPs.
Since you're coming from Cisco, I would check that you added all VLANs tagged on both ends of the uplink first. Cisco trunks everything so that would be easy for you to miss.
Charles Cox
Indeed, so many questions so I am trying to learn extreme basically by reverse engineering the existing equipment.  Are there some better commands to show port:vlan settings?  I get the long output from the 5 sw in the stack, but I am having trouble finding just a comprehensive 'this port is a member of these vlans,' (4 vlans but doesn't tell me which vlans unless its a single vlan)
And just to be clear: Trunking on extremes is just adding a port to more than one vlan, tagged?
Photo of EtherMAN
EtherMAN, Embassador
  • 7,170 Points 5k badge 2x thumb
Some of my favorite doing network connection and discovery with examples
here is a jumpstart guide that gives you a lot of the basics.... All so remember tab is your best buddy
http://learn.extremenetworks.com/rs/extreme/images/Extreme-Networks-Deployment-Jumpstart.pdf
show edp port all detail ... this will give you neoghbor detail about any two extreme switches that share a link including the vlans that are share don the link..
Port 1:1: EDP is Enabled
Tx stats: sw-pdu-tx=0          vlan-pdu-tx=0          pdu-tx-err=0
Rx stats: sw-pdu-rx=0          vlan-pdu-rx=0          pdu-rx-err=0
Time of last transmit error: None
Time of last receive error:  None
Port 1:2: EDP is Enabled
Tx stats: sw-pdu-tx=353518     vlan-pdu-tx=353517     pdu-tx-err=0
Rx stats: sw-pdu-rx=353507     vlan-pdu-rx=353506     pdu-rx-err=0
Remote-System:          PLW_X460G2_5959Basement_stack   Age = 11
Remote-ID:              00:00:02:04:96:9a:37:be
Software version:       15.6.3.1
Remote-Port:            1:25
Port Type:              Ethernet
Auto Negotiation:       ON
Flow Control:           NONE
Duplex Speed:           Configured = AUTO       Actual = FULL
Port Speed (MB):        Configured = AUTO       Actual = 1 Gbps
Remote-Vlans:
        nm_phono_3801 (3801, 192.168.231.196)  Age = 13
        plw_wapcom_774 (774)  Age = 13
        plw_servers_773 (773)  Age = 13
        plw_srx_dmz_775 (775, 10.80.253.4)  Age = 13
        private_plw_792 (792)  Age = 13
        plw_inet_dns1_598 (598)  Age = 13
        plw_inet_dns2_597 (597)  Age = 13
        plw_inet_plw5959_2396 (2396)  Age = 13
        plw_srx_toweroaks_769 (769)  Age = 13
Slot-2 PLW_X670G2_5959_Stack.2 # sh por 1:2 info detail gives you vlan info detail on that port plus other things
Remote-Port:            1:25
Port Type:              Ethernet
Flow Control:           NONE
Remote-Vlans:
Port 1:3: EDP is Enabled
Port 1:4: EDP is Enabled
Port:   1:2(p1-2_460G2-1-25):
        Virtual-router: VR-Default
        Type:           SF+_OC10m (Unsupported)
        Random Early drop:      Unsupported
        Admin state:    Enabled with  1G full-duplex
        Link State:     Active, 1Gbps, full-duplex
        Link Ups:       0        Last: Mon Oct 16 11:25:16 2017
        Link Downs:     0        Last: Mon Oct 16 11:23:36 2017
        VLAN cfg:
                 Name: nm_phono_3801, 802.1Q Tag = 3801, MAC-limit = No-limit, Virtual router:   VR-Default
                       Port-specific VLAN ID: 3801
                 Name: plw_inet_dns1_598, 802.1Q Tag = 598, MAC-limit = No-limit, Virtual router:   VR-Default
                       Port-specific VLAN ID:  598
                 Name: plw_inet_dns2_597, 802.1Q Tag = 597, MAC-limit = No-limit, Virtual router:   VR-Default
                       Port-specific VLAN ID:  597
                 Name: plw_inet_plw5959_2396, 802.1Q Tag = 2396, MAC-limit = No-limit, Virtual router:   VR-Default
                       Port-specific VLAN ID: 2396
                 Name: plw_servers_773, 802.1Q Tag = 773, MAC-limit = No-limit, Virtual router:   VR-Default
                       Port-specific VLAN ID:  773
                 Name: plw_srx_dmz_775, 802.1Q Tag = 775, MAC-limit = No-limit, Virtual router:   VR-Default
                       Port-specific VLAN ID:  775
                 Name: plw_srx_toweroaks_769, 802.1Q Tag = 769, MAC-limit = No-limit, Virtual router:   VR-Default
                       Port-specific VLAN ID:  769
                 Name: plw_wapcom_774, 802.1Q Tag = 774, MAC-limit = No-limit, Virtual router:   VR-Default
                       Port-specific VLAN ID:  774
                 Name: private_plw_792, 802.1Q Tag = 792, MAC-limit = No-limit, Virtual router:   VR-Default
                       Port-specific VLAN ID:  792
        STP cfg:
        Protocol:
        Trunking:       Master port with 2 members using algorithm address based - L2
algorithm
        Members:        1:2,2:2
        EDP:            Enabled
        ELSM:           Disabled
        Ethernet OAM:           Disabled
        Learning:       Enabled
        Unicast Flooding:       Enabled
        Multicast Flooding:     Enabled
        Broadcast Flooding:     Enabled
        Jumbo:  Enabled, MTU= 9216
        Flow Control:   Rx-Pause: Enabled       Tx-Pause: Disabled
        Priority Flow Control: Disabled
        Reflective Relay:       Disabled
        Link up/down SNMP trap filter setting:  Enabled
        Egress Port Rate:       No-limit
        Broadcast Rate:         No-limit
        Multicast Rate:         No-limit
        Unknown Dest Mac Rate:  No-limit
        QoS Profile:    None configured
        Ingress Rate Shaping :          Unsupported
        Ingress IPTOS Examination:      Disabled
        Ingress 802.1p Examination:     Enabled
        Ingress 802.1p Inner Exam:      Disabled
        Ingress 802.1p Priority:        0
        Egress IPTOS Replacement:       Disabled
        Egress 802.1p Replacement:      Disabled
        NetLogin:                       Disabled
        NetLogin port mode:             Port based VLANs
        Smart redundancy:               Enabled
        Software redundant port:        Disabled
        IPFIX:   Disabled               Metering:  Ingress, All Packets, All Traffic
                IPv4 Flow Key Mask:     SIP: 255.255.255.255            DIP: 255.255.255.255
                IPv6 Flow Key Mask:     SIP: ffff:ffff:ffff:ffff:ffff:ffff:ffff:ffff
                                        DIP: ffff:ffff:ffff:ffff:ffff:ffff:ffff:ffff
        Far-End-Fault-Indication:       Disabled
        Shared packet buffer:           default
        VMAN CEP egress filtering:      Disabled
        Isolation:                      Off
        PTP Configured:                 Disabled
        Time-Stamping Mode:             None
        Synchronous Ethernet:           Unsupported
        Dynamic VLAN Uplink:            Disabled
        VM Tracking Dynamic VLANs:      Disabled
show ipr gives your routing detail and any vlan that has an ip configured with ip forwarding enabled is routing between vlans
Slot-2 PLW_X670G2_5959_Stack.3 # sh ipr
Ori  Destination        Gateway         Mtr  Flags         VLAN       Duration
#s   Default Route      192.168.231.1   1    UG---S-um--f- nm_phono_3801 729d:10h:41m:1s
#d   172.16.59.0/24     172.16.59.1     1    U------um--f- PLW_San_595 729d:10h:41m:2s
#d   192.168.231.0/24   192.168.231.107 1    U------um--f- nm_phono_3801 729d:10h:41m:2s
Charles Cox
Sweet thanks guys, and yes I to love TAB!
