Is there any tool or Command for comparing the VLANs from Two Switches?
  • 2
  • Question
  • Updated 2 years ago
  • Answered
  • (Edited)
I have Ten Switches but each having 200 or 300 VLAN's.
My Question is, What is the right way to compare two Switches (VLAN) ?
Is there any tools or commands for comparing those VLAN's ????
Because I want to check all the Switches and want to configure the Missing VLAN's..!!
Kindly help me out in this...!!!!!
Note : All are Extreme X450e-48p Switches.
Photo of Boopathy Chandrasekar
  • 396 Points 250 badge 2x thumb
  • Confused
Posted 2 years ago
  • 2
Photo of Matthew Hum
Matthew Hum, Principal Engineer, APAC
  • 1,542 Points 1k badge 2x thumb
Netsight has a config compare tool. This will show you what is added/deleted/changed between 2 different config. If you compare 2 different switches it will show a lot of other changes, but you can just focus on the VLANs.
Please see Netsight Help -> OneView -> OneView Features -> Compare Device Configurations
Its really nice way...!!!
Thanks a lot Mr.Matt :)
Photo of Vellachery, Sumeesh
Vellachery, Sumeesh, Employee
  • 3,116 Points 3k badge 2x thumb
ExamDiff is a Freeware Windows tool for visual file comparison. You could also try that..
Its really superb :) :)
Its Working....!!!!!!!
Thanks Mr.Sumeesh.!!!
  • 210 Points 100 badge 2x thumb
There are a lot of comparing tools available online. Just Google it.
Photo of Jeremy
Jeremy, Embassador
  • 9,788 Points 5k badge 2x thumb
Or, just paste a complete config of all your vlans on each switch... then they will be all up to date.
In my case , All the switches are live (Production)
Are you sure, it will not affect the live Switch ????
I don't want to take Risk by applying all the commands on Live Switches..!!!!! :(
Am I right ????
Yes, it would affect the switches and it is not recommended to do it in a production environment.
First Edit the configurations as you wish and then paste it on the switches.
Yes, I too agree with you..!!
Thanks for your Response.!!!
