Job scheduled with PING to...
  • Question
  • Updated 3 weeks ago
I would create a scheduled job that ping a particular port and give me an alarm if the pc connected at this port do not respond
Photo of Visconti
Visconti
  • 764 Points 500 badge 2x thumb
Posted 4 weeks ago
Photo of David Coglianese
David Coglianese, Embassador
  • 7,208 Points 5k badge 2x thumb
You could simply add the PC as device using Ping and easily get an alarm if the device goes down.
Is that what you are looking for?
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 49,992 Points 20k badge 2x thumb
Good point but be aware that then the PC counts as a device and uses a device license from the XMC device pool.
That is a good point Ron.
I deal with a lot of K12 who all have the unlimited bundle and didn't even think of that.
Photo of SH
SH
  • 4,816 Points 4k badge 2x thumb
Hmm,
I want K12 here in Germany, too. Then I see more unlimited bundles and I do not have to worry about the licenses anymore ;-).
Stephan
Photo of Visconti
Visconti
good idea but I receive any problem with SNMP time out Contact lost!!!
I try  to modify the snmp time out value?
In all device I can do it but not in this device type
  • 7,168 Points 5k badge 2x thumb
You would want to discover the device using ping NOT SNMP.
  • 49,972 Points 20k badge 2x thumb
Just to make sure.... that has nothing to do with SNMP - XMC polls the end-device via ping.
If you add the device (PC) you choose "ping only" in the profile section instead of SNMP profile.
If the PC is disconnected/shutdown you'll get a alarm.
Photo of Visconti
Visconti
Sorry but I am a  beginner...can say me how can I discover with ping?
Photo of Visconti
Visconti
Ah okkk!!!!!
I think I've found a bug.... if you add the device as mentioned above with profile ping only the poll type is set to SNMP and then it doesn't work.
Workaround > right click the device > device > configure device > set the poll type to ping > save
example with wron g poll type....
Photo of Tomasz
Tomasz
  • 1,764 Points 1k badge 2x thumb
How about an EXOS TCL script scheduled, so the XMC would log in to the switch, perform ping or show fdb or anything else and by parsing the output ($CLI.OUT variable) you could see what's going on...?
From EXOS side you could play with UPM scripts and EMS-based event trigger so once a port is down (or else) you would take care.
Or you can do that without any need for proactive action - an edge switch should syslog its events, and with XMC alarms you can wait for appropriate event showing port X is down so the alarm goes up.
(Edited)
Photo of Visconti
Visconti
I have 12 switch B5 series and 2 x450 so I need 2 CLI type?
Photo of Visconti
Visconti
can you explane me how can I do this ?
It's very interessant but I am a beginner..
I must use CLI ?
(Edited)
Photo of Tomasz
Tomasz
In the topic and in categories I didn't see EOS, sorry. With B5 I don't believe TCL type scripting is possible. :(
I think David's option to add a device to XMC with "ping only" poll type sounds good but it consumes your license so it's not scalable.
(Edited)
Photo of SH
SH
Hello Visconti,
if you want to protect you XMC licenses you can write a XMC script. Following setup:
  1. Ping Device (IP). Does not have to be a switch configured in XMC!
  2. Parse the result of the ping
  3. If the ping fails create an syslog entry (you can use the little program "logger" available on XMC on Linux platforms.
  4. Set an alarm (with the XMC alarm manager)
Best regards
Stephan
